A55 Smoothing Plane
Pen turning questions
Steven Antonucci
steve antonucci
>I'm looking for the collective wisdon of all of the high end pen makers on this board...
I have probably turned a hundred pens or so, but I wouldn't say that I'm a "high end pen turner". For some reason, I can not get the barrels to be "perfect"- there's always a tiny ridge on the pen that you can't see but you can feel as your fingers pass over the transition points. I'm guessing it's the thickness of a sheet of paper or two.
So my question to you all?
How the heck do you get it to be "perfect"? What's your alignment routine and how you you know that the mandrel doesn't have any runout?
I've got some Christmas presents to make and I'm always looking to get better...
Steve
Re: Pen turning questions
I Do The Following
Jim Shaver Oakville, Ont.
>Hi Steve,
Sounds like you have an "out of round" condition. What that means is that there is an amount of stress on the mandrel that makes the pen body turn not turn to round.
A number of things can contribute to this. Several include, a mandrel that is bent, too much tail pressure on the mandrel shaft from the live center, the brass nut is too tight that holds the pens and bushings on the mandrel.
I follow several basics when I set up my pen blanks. I keep the adjustable mandrel I use and short as I can, I tighten the nut on the mandrel finger tight and I apply just a light tail stock pressure to eliminate vibration.
I also use a live centre with a 60 degree cone, it matches the indent on the end of the mandrel shaft. The stock cones seldom match this angle.
Before the final few passes to size, I re-hone my skew, undo the assembly on the mandrel and reassemble (it can over tighten itself as you turn, especially on larger diameter pens).
Light passes taking it to almost the diameter of the bushing is what you want to do. Undersize to the bushing is bad news for the "Finger Feel" as you know.
I get as close as I dare, then I burnish the edges on a piece of leather to soften the edge, makes the blank to hardware transition less noticeable if the sizing is not perfect.
Hope that helps, others will give some input I hope.
Take care,
Jim
Steven Antonucci
I think you've nailed it
steve antonucci
>I'm not oversized all the way around, but only on one small section in the whole pen body. I may just go cut the mandrel down to turn only one section at a time.
Thanks for your input.
Steve
P.S. How do you end mill an odd size pen blank? I have a 7mm mill and all kinds of bushings, but nothing for the 31/64 and 33/64 pens I've been turning.
Re: I think you've nailed it
>Hi Steve,
Milling ends is important to get square or the hardware to pen blank will have a gap...been there, done that!
Some people use a sanding centre (like a Delta with a 36x4 belt and a 6 inch disc) with a square guide so you can touch the blank end face to a spinning sanding disc and get it flat..I have a bunch of the mill guides that CSUSA sells, not cheap, but I never have a problem.
Let us know how you make out...I like to turn both pen top and bottom bodies together so I can create shape and keep the sizes in proportion.
Take care,
Jim
Ron in Drums PA
>Jim has given you some excellent advise.
Many times the bushings are a different size then the pen parts. This can happen when we sand the bushing along with the blank. Eventually the bushing gets smaller. Other times the pen parts or the bushings are simply sized wrong to begin with. Now add the fact that many pen turners turn the blank to match the bushing size and you can see why problems may happen.
Check the bushing to the pen nib with a micrometer and see how the match up.
I always use a micrometer to turn the blank to match the nib and never use the bushing to match the nib.
Ron in Drums PA
>I turn my own with maple
Russ Fairfield
>Sometimes the out-of-roundness is caused by the sanding. Softer wood sands away faster, and the grain of the wood will make one side of the pen harder or softer than the other. Burl is bad about having different hardness. The better the finish left by the turning tool, the less sanding with finer grits is required, and the less this is a problem.
Great Point!
>You are right Russ,
Have you ever noticed how you can "feel" the figure in a piece of curly figured wood as it's spinning and you are sanding it....dense wood-light wood.
I seldom start below 400 when sanding natural woods, even finer with stabilized or man made materials...that final pass with the tool edge is a real important cut, I call it the Money Cut.
Take care,
Jim
Steven Antonucci
might be contributory as well
steve antonucci
>I used a skew (very well, I might ad-patting myself on the back :-) to fnish off the pen I made tonight (thuya burl) and the finish was great right off the skew. Sanding it (400, 600 and 2000) didn't seem to help all that much.
next time, a nice sharp skew and some finish! Thanks!
steve
P.S. I did cut my mandrel down by about 3", since the problem ALWAYS seems to occur in the middle of the pen, and never at the ends.
Bill Blasic
Bill Blasic
>Before I take my final cut I always loosen the knurled nut and turn the blanks 90 degrees just in case I had too much pressure on the mandrel and the blanks were slightly out of round. I then retighten and take final cut, sand and finish, works well for me.
Bill
Re: might be contributory as well *LINK*
dwr
>Steve,
They have a mandrel that is hollow and allows you to shorten the length of the rod to suit whatever you are turning. Sells for around $25-$30 in most places. Much better quality than the old black rod mandrels, IMHO.
Also, I have found that the speed at which you sand is also important. Beyond a few hundred RPMs, the heat can cause the wood/barrel to distort... not to mention removes more wood than you realize until it is too late.
After slowing down the lathe and following some of the points others have listed, my quality improved dramatically.
DW
Adjustable Pen Mandrel
