Re: Also got a light on my lathe.
Jeff from MA
>Over the weekend I added lighting to my lathe as well, it makes a big difference. I have two lights similar to the one you show in your photo, but have replaced one of them with a 20W halogen with a sealed head, a flexible goose neck, and most importantly a magnetic base. The base attaches just about anywhere on the lathe there is a flattish spot, the ways, the side of the head-stock, the tail-stock, or even the outboard tool rest.
The magnetic base makes it easy to get light into a workpiece's details or under a rim of a vessel. The lamp head is probably about one quarter the size of the incandescent lamp, so it doesn't get in the way as much. I also feel a little safer with the bulb inside the sealed head, less of a chance of the fragile glass bulb hitting anything that is spinning (or flying). I found my light up on the net doing a search for "machinist task lighting".
More light is definitely better, but it seams to be the cause of a lot of very fine scratches :)
-j
