Jet mini bearing question
keith zimmerman, Normal IL
>It looks like I will be needing to replace the bearings in my Jet mini VS pretty soon. It's starting to get pretty loud when I'm turning and the headstock is quite warm, almost hot.
Where can I get them? How hard are they to replace? I've never done anything like that so any tips, how to's, advice, etc. would be greatly appreciated.
keithz
Re: Jet mini bearing question
Hope you get better anwers to other
Don Henthorn
>parts of your question, but to purchase go to your local bearing and gear place. It may have another name but will sell bearings, belts and all sorts of drive parts. Good quality sealed bearings will be less there than ordering from Jet or other tool supply houses. Remove the bearings and take one in with you and they will match it for size. Be sure to get a good sealed bearing, not just one that matches the original.
Doug Thompson near Cleveland
>Keith,
I never changed bearings on a Jet mini but the basic idea is the same. To start loosen the set screws on the pulley and spindle lock. Use a piece of wood and slide them towards the hand wheel. NOW remove the hand wheel and nut on the end of the shaft then use a rubber mallet to tap the end of the shaft. It should come right out. Like Don said go to the local bearing distrubutor and let them match it up. Ask if they have a higher quality bearing and the price... it might be a few bucks more.
If you have any questions ask,
Doug
>On the Jet mini you just loosen the set screw on the handwheel and screw the handwheel off. Then loosen the setscrew on the drive pulley. (remove the tension from the belt of course). Then the shaft should push out from the handwheel side I think (haven't done this in a while). I haven't removed the bearings from mine yet but if it's typical you may have to knock them out with a block of wood of the appropriate size.
You can easily find these at your local bearing supply house. Hopefully you can press them back in place but if not some gentle persuasion with a block of wood of the right size. The problem is you may have to turn this block so take that into consideration before you dissassemble the lathe. The wood should only touch the outer race of the bearing.
On the Jet mini the handwheel also acts as a tension adjust on the bearings. If you tighten it too much it will strain the motor, too little and you get vibration. It's an easy adjustment, just tighten it until the shaft rotates freely but there isn't any slop. Then turn something. It if vibrates tighten the handwheel another tiny amount.
I put a second set screw in my handwheel so if you have the tools I would do this while everything is apart. The handwheels on the Jet have a habit of getting loose which sets up vibration in the drive spindle. A second set screw prevents this.
Terry Quiram, Roanoke Illinois
>Keith
Motion Industries in East Peoria can replace your bearing. If you identify the bearing number I can stop on the way home and pick one up for you.
Terry
Larry In Lima
>Ah finally... Something I can contribute to again...
You need a 6004-2RS, and a 6005-2RS bearing. As to do doing the work, it's been posted already. This is for the non-VS Jet Mini, not sure about the VS, but I'd almost be they are the same being alike in so many other ways. Larry
Keith Tompkins
Keith Tompkins
>Keith , some installation tips.....when installing the bearings, tap them in place against ONLY the outer shell of the bearing..don't touch the inner race at all o/w damage can result.The outer shell of the OLD bearing with a block of wood behind it will be ideal. Ensure the bearing starts straight in, not cocked.
If installation is stubborn, use a threaded rod, washers, and nuts to pull the bearings into position, again applying pressure against only the outer edges.
When installing the spindle, ideally, support the INNER race...again, this will prevent damage to the bearings. In other words, never apply pressure to the bearing surfaces inside each bearing. I've pressed lots of bearings....even under great pressure while installing, the bearings should still turn, if not, the bearing is being damaged. Hope this helps
Thanks for the advise
>Thanks to all who responded. I hope I will be able to get my Christmas orders completed before things get too bad and I have to replace the bearings.
Terry, thanks for the offer. I will definitely take you up on it. I'll get the numbers and send them to you.
keithz
Re: Hope you get better anwers to other
bob davis
>take both .they are different sizes
Aage Rendalen
Same happened to me
Aage Rendalen
>My Jet-Mini headstock bearing began creating trouble less than a year after I had bought it. Woodcraft here in Richmond, Va offered me a new lathe, so I don't have any insights into changing the bearing but I find it troubling that this may be problem with this otherwise great lathe
