Re: Website check -- Issue found
Brodie Brickey
>Sean,
Site looks great. Very pleasing to the eye.
The only issue I've found is that the main menu's open in new windows. This can become very annoying. I'm also using Firefox which is a little more literal in its interpretation of the code, but IE should perform the same way.
To fix the problem and have it open in the same window, you will need to remove the ' target="_blank" ' from the "A HREF" tag. You may also need to display the menus into the other main landing pages like "Photo Gallery" or Links.
If you do decide to continue keep popping new windows, the target should have the same name so that it will always reuse the same window (ie. window 1 is your home page, window 2 is named 'main'[the "A HREF" tag includes 'target="main"'] the links page would open with a window name of main, if you click on Photo Gallery the links page will be replaced by the photo gallery.) In the event that the second window is not already open the browser will just open a new window and give it the specified name.
I hope this helps.
Regards,
Brodie Brickey
www.SmoothTurnings.com
