Ideal height for lathe
Ray Binnicker
>Is there an ideal height for a lathe? I feel like it ought to be according to the person's height, or what the individual is comfortable with, but am interested in how you guys figure it out.
Thanks
Ray Binnicker
Thanks
Re: Ideal height for lathe
Dick Hines
>It depends on your height. Most people could not use my lathe with out standing on a box. My spindle height is 50+".
Ron in Drums PA
>Spindle height should be about elbow height. Mine is a little lower, I've always planned on raising it, one day.
>Most people start at elbow height. Bend your arm amd measure from your elbow to the floor. Many move it slightly higher. Mine is 1" higher than my elbow height. The only way to really know is to turn a lot. I was having back problems so I move the lathe higher and they stopped.
Re: Position it where it feels .....
Jamie Donaldson
>.. right after a long day of turning. And like John said, your back will let you know wrong from right!!!
Mkauder, Phenix City, AL
>Depends on what you do with you lathe. The standard line about having at elbow height is based on using the lathe mostly for spindle work.
If you do open bowls, the elbow height will work, but if you move your headstock and turn at the end of the lathe to do bowls, then a little higher seems to be more comfortable.
If you do alot of hollowing (again working at the end of the lathe) even higher seems to be comfortable since you are not spending all your time crouched down trying to look inside. I am 5'10" and my spindle is in the 49" range. As a result, I tend toward longer handled gouges (oneway, bosch, etc) so that I can still keep them on my hip while turning.
Mark
Rick Davenport
>If you are yea tall, it should be yea high!
Give or take a few inches.
R
Allen Neighbors
>Ray, I'm 5'10" tall. My Lathe Spindle is centered on 49". I turn mostly bowl and hollowforms interspersed with eggs and screwdriver handles.
My 'Old Griz' is about 42-44 inches, and it's too low for me to be comfortable.
When I had it at elbow height, I had back trouble. Since I've put my Oneway at 49" I haven't had a back problem at all. The only problem I have with it that high, is when I try to ride the ways when turning. I do that once in a while, turning the inside of bowls. :o)
Suggestion: Start it at about elbow height, or put it where you think you want it, then add 3/4" blocks under each leg... try it a day or so... raise it or lower it as you see fit. When you get it where you want it, make it permanent.
There's only one real rule in woodturning: Have fun!
HTH :o)
Wow- I was guessing wrong!
steve antonucci
>I figured most people turned about elbow height (that's what we've all read...) but I think the best answer is going to be "it depends".
I a 6'1" and my spindle is about 44.5" off the ground. When I hollow, that feels too high and I'd actually want to lower it if there was an easy way (I know I can build a platform...) I wouldn't want my lathe to be any higher (I think?) because I turn a lot of big wood and I don't always round it off so well. The higher center of gravity would magnify any "walking". As it is, my lathe is barely in the garage anymore :-)
I guess it all depends upon what you've gotten used to...
Steve
Re: Wow- I was guessing wrong!
georgetroy
>I'm approx. 5'9", Some days it's higher or lower. My ideal height for me seems to be at approx. 43". My arthritics does not like my arms up high. My stomach and waist is my power point not my bosum. No back trouble here even though I grew up in the roofing business. GT
Don in Central Illinis
>Love that response. And it's so accurate!!!!
Mike Cunningham (Cape May)
>A starting point would be the height of the tip of your middle finger from the floor with your arm flexed and forearm parallel to the floor with your fingers extended. I'm 6'4", the mid-point of my spindle is 50 1/4" which is about 1 1/4" higher than the measurement described above. I like my lathe raised high. I have a portable platform of 2X4 and 3/4" ply for shorter turners.
gtwilkins
>I'me 5'10" elbow at 44" above the deck and the spindle on the Vic is 46", comfy but I do mainly bowls and hollow forms,Trevor
