We value your privacy.
>Turners, many of you have experience using Inlace or similar products. I posted a question about this on the general message board. If you have time, could you advise? I need to fill a 1/8" gap on all four sides of a project. Inlace sounds right, but I have never used it. Can you offer tips?
I've only used it once but I've also talked with others who also have experience with it. It seems that Inlace can be mixed to a "desired" thickness and if too thin it will sag out of it's boundries if it's in a vertical orientation. If mixed too thick, it may set up too fast on you. I'd suggest a horizontal positioning of your work piece if possible. Hope this helps and I also hope others with more experience with the product will help us both.
>Actually when you first stir in the hardener it is thin and will run easily. If that is the consistency you want just go ahead and start. If you need a thicker consistency for vertical application just keep on stirring and wait. It will start to thicken and you can apply it. Once it starts to thicken it happens fairly quickly so be ready. Be prepared to keep moving it around pushing it into the areas needed while it hardens. You can also mix up smaller quantities and then support your work so you don't need the thick stuff. You can also make little dam's out of masking tape to hold it into certain areas. You said you have 4 sides to do. I would do one or 2 sides at a time.
The 5 minute epoxy I mentioned on the other board is a little harder to control. Once it starts to thicke it goes very fast so you really have to be ready. For this stuff I dam up the are and set the work so gravity will do the job and just let it harden. Then move on to the next area.
>You can purchase "thickeners at many places including "Turtle Feathers" who sells inlace for gourd work. Any place that sells epoxy resins for say boat repair will have it. There are several types of thickeners some good some not good for wood work. Inlace works well but if the wood is green the inlace will not shrink when dry so if the wood is still moving you may have difficulty in the finished work.
If you wait until the resin starts to cure as suggested the chemical process has started and the polymer strings are already forming so that is a way to do it but takes care and probably is not the best way thickeners are a better approach.
>Thanks to all for you tips. It sure would have been easier to do the glue up the right way in the first place. Then again, anybody can do it right the first time; it takes a true craftsman to fix it! :-)
