new lathe
new lathe
new lathe
Randy Szkola
>I am looking to purchase a new 12-14" lathe for hobby turning of bowls , I am looking At the Jet 1236 or the delta 14 " ,have also seen harbor frieghts 12", any Coments are welcome as I want to make the correct decision.
Thanks
Re: new lathe
Re: new lathe
Greg Haugen
>I would stay with Jet, Delta, or any "name" brand. Harbor Freight sometimes has good tools. But even the best tool sometimes may need to be serviced and with them you're S.O.L. I would go with the Delta 14" lathe between the Jet 12" and the Delta. More weight, heavier duty, a larger swing, and more horsepower-I think. That's the lathe I started on and it was great. I would recommend running a 2x12 between the legs and put sand bags on it. The added weight will greater reduce vibration. The Delta is a little more money but its more lathe also.
Hope that helps.
Greg
Re: new lathe
Re: new lathe
>Randy If you can the Jet 14" is better than the 2 listed I think.
Re: new lathe
Re: new lathe
Jack Savona
>Nay, nay to the Delta. Too many quality problems and a noisy Reeves drive. DAMHIKT.
Jack
Re: new lathe
Re: new lathe
Greg Haugen
>I would definately agree with that. It is more money, still has the reeves drive but is alot more sturdy.
Greg
Re: new lathe
Re: new lathe
Mike Cunningham (Cape May)
>Of those three....The Jet.
Re: new lathe
Re: new lathe
Steven Smith
>Randy, I have had a Jet 1236 for about 5 years and could not be happier. It has not had one problem and is big enough to turn anything that I want to turn. I also know one person that has the delta and he has had problems with his. The extra weight from some sand bags is a good idea. I dont know about the Delta but the Jets also have a pretty good resale value.
Re: new lathe
Re: new lathe
Randy Szkola
>Thanks for all the feedback ,seems like jet is the way to go ,some of reviews on the delta talk about bad bearings and that the factories in China are not consistant with using the same bearings and other parts .Is the Jet made in the USA ? Would be nice to get something that still is
Re: new lathe
Re: new lathe
>Nope
Re: new lathe
Re: new lathe
Greg Haugen
>No, the Jet is made overseas. The parent company that owns Jet also owns Powermatic and some others. They do have nice equipment and are starting to push Delta out. Delta upset alot of people when they got bought out by Black and Decker/Dewalt. I do think that the Jet company has a better "quality control" in place. It does show in some products.
Hope that helps,
Greg
Re: new lathe
Re: new lathe
>The Delta original bearings which are very poor and the ends are plastic (can we say easily contaminated) and the noisy vibrating drive. The bearings are easily replaced. The drive isn't easily replaced. It only has 3/4 hp. This was my first lathe, since replaced.
Don't know enough about the Jet 1236, I haven't turned on one.
If you just want to turn bowls as opposed to spindles, consider the new General "Maxi" lathe (25-200). I saw one at a distributor's "show" and I was favorably impressed. It has a 12" capacity for bowls over the bed and a 3/4 hp motor (and it pivots to a large capacity, but I didn't see that demonstrated). It has three variable speed ranges.
(Not an employee or connected with General in any way. Just think it is an interesting little lathe.)
Re: new lathe
Re: new lathe
Bill Hale / Woodspinner
>Randy If you can afford it go for a VS drive and a min of 1.5 HP.
You may pay a little more but the fun and value is worth it.
Welcome to the group.
Good turning and be safe,
Bill in Casa Grande, AZ.
Re: new lathe
Two places with possible good prices
Craig Daymon
>Here are 2 places that stock refurbished and new equipment at good prices. Both speciailize in Wilton products (Powermatic, JET, Performax, etc.). I have no clue why the one would decide to redo their site this time of year, but they usually have some fantastic deals on "Scratch & Dents", which usually means scratched paint.
General Industrial Supply
http://www.generalindustrialsupp.com/
Equipment Sales & Surplus (I bought my 3520A from these guys.)
http://www.equipmentsalesandsurplus.com/
-Craig
Re: new lathe
Re: new lathe
Randy Szkola
>What is a VS drive ?
Re: new lathe
Re: Variable speed...
>You can turn a dial for the speed in a particular range as opposed to changing belts. The electronics vary the speed in a particular range (you have two or more spindle pulleys and you move the belt from low range to high range).
A Reeves drive has a "variable" pulley. The motor shaft turns at a constant speed and when you turn the lever, the "diameter" of the spindle pulley changes. This gives you a speed range. Unfortunately, there often is more vibration.
Re: new lathe
>The Reeves drive is quite old and works well although you have to clean the shafts and keep them well lubricated. Good drives with good belts run very well. The cheaper belts take a set when not used and cause vibration. The bad side, they need maintenance. The good side, there isn't anything you can't fix if your mechanically inclined.
electronic variable speed is the relatively new thing to woodturning. You simply turn a dial and change speeds. DC variable speeds lose power at lower speeds. The new kid on the block is Variable Frequency Drives. These take 220vac and change it to run a 3 phase motor and it varies the frequency. You get maximum power even at the lowest RPM. These drives are really handy. The downside is that you really can't repair them and having them repaired or replaced is quite expensive.
I do like the new electronic things but there's really know substitute for the good old miltistep pulley. Other than some setscrews coming loose or a brocken belt, there's nothing to go wrong.
OK that's a little over simplified but I hope it explains variable speed.
Re: new lathe
Re: What about the Griz 16" 2HP?
Allen Neighbors
>Nearly everyone on this forum knows I started with a Sears, then a Grizzly. Had to do some tweaking on the Grizzly, and after that tweaking, it's been a decent lathe... except the motor is only 1/2 HP.
They're advertising a 16" Swing X 42 between centers, 2HP, VS w/digital readout, Cast Iron legs, in their catalog right now for $395. That's what I paid for my 12X36 3 years ago. I'd say it's a decent starter lathe, for $395, even if you do have to do some tweaking. :o)
.02
Allen
Re: new lathe
Ric Taylor
Re: new lathe
Ric Taylor
>Randy,
Many of us started with the Jet 1236. It's a great trouble-free machine that will do just about anything a newbie wants to try, and it holds it's value very well. You can use it for several years, then easily sell if for about what you paid for it if you want to change to another lathe. After turning for awhile you will discover what you really enjoy making on the lathe, and then you might want to switch to a larger or smaller machine to suit your needs.
In my opinion, there are too many questions about Delta equipment out there right now.
Ric
Re: new lathe
Re: new lathe
Rick Bane
>I happen to own a delta machine-a 1440. yeah the motor is a little small but so far the only issue that I have had has been the on/off switch and it was sent to me UPS and was not a problem with service of any kind. The machine to me ( a newbie-only a couple of years of dabbling in it ) seems to be nice. It has a swivle head witch I like alot and the price was right!! I do want to upgrade eventually but for a while this machine will serve me well, hopefully!!!!
Rick
