Neutralizing 2 Part Bleach
Carole Valentine
>Is it absolutely necessary? I have bleached pieces before and not neutralized. They seemed fine, but I wonder if there is any long term negative effect from not doing it? The wood in question is holly.
Re: Neutralizing 2 Part Bleach
George Balock
George Balock
>Carol,
I'm like you and have not had any problems with not neutralizing. I'm interested in seeing what others have to say.
George
Ed Heuslein
>Howdy Carole: I've use this system many times. At first, I neutralized. I no longer do. I see no difference in the final product. The only problem I've thought about is if there is any sanding between the bleaching and the finish, perhaps some of the dust could contain irritants if it gets into the eyes or lungs. I don't sand except afte the first coat, and I've never had any problems.
One last thing. Consider a water based product (I use water based lacquer) for your holly. It won't yellow and the "white white" really stands out.
Ed
Carole Valentine
>Thanks Ed. I just found some FAQs printed on the inside of the box and it says you only need to neutralize if you use more than one application. This holly was already very white, but I just thought I would see if it would get any whiter. I don't use any finish on holly. I sand to 12,000 micro-mesh, buff with white diamond and polish with Renaissance wax.
