2 quick newbie questions
Paul2
>I have just started turning, and have two quick questions I hope someone can answer.
The first one, is it safe to use an 8", 3750 RPM grinder with one wheel missing. Will running it with only one wheel be in some way detrimental to the grinder?
The second one, is a bowl's base more resistant to cupping when it has a flat bottom, rather than a rim? I made one with a rim and it cupped a little, so I was wondering if I had left it flat, would it have prevented the cupping.
Thank-you,
Paul
Re: 2 quick newbie questions
Lan Brady
>Paul,
I can only give you an amatuers point of view.
1. The grinder will work safely, but will wear the bearing much faster.
2. All wood is going to move some over time. It will be much easier to correct a rim than it would be to flatten an entire bottom.
Good Luck, Lan
Brad Vietje
Bowl part...
Brad Vietje
>Hey Paul,
Thanks for posting the question. I'm no expert on grinders, so I'll steer clear of that one.
As for bowls, both shapes will warp. Generally, the more spherical a shape is, the stronger, and the less likely to change shape. Flatter shapes are weaker. However, green wood will warp as it dries, no matter the shape, and even air-dried, or kiln-dried wood will move a little after turning, as the wood you remove was part of a larger structure -- when you remove some of that structure, you are changing the balance of stresses in the wood which can result in slight movement. If you want a piece to be as close to perfectly round as possible (or box lids to fit just right), then even dry wood should be allowed to release internal stresses for a few hours after turning and before you're completely done with the lathe.
The specific answer to your particular question will depend on how dry the wood was to start with, sometimes even the wood species, how the bowl was oriented in the wood (think of how that bowl would have been placed in the living tree, if possible), and whether the bowl was part-turned when green and then finish turned after it had dried. If you can tell us more, you'll probably get a better answer.
Safe spinning,
Brad Vietje
Newbury, VT
>Paul No problem on the grinder they are designed to be run with 2 wheels, 1 wheel and a wire wheel, or 1 wheel and a polishing wheel, 2 polishing wheels, etc. I'm sure there are specific grinders for specific duties but I would think most of the less expensive ones are designed to hold up under all sorts of amatuer usage.
Ric Taylor
Ric Taylor
>Paul,
If you make a bowl with a perfectly flat bottom, it very likely will not sit flat on a table. The wood will warp or move, at least a little bit, then the bowl will wobble on the table. That is the main reason why bowls, dishes, platters etc etc etc mostly have rims on the bottom. It helps to ensure that it won't wobble on the table.
Ric
Bill Hale / Woodspinner
>As the others have said all will warp and some worse than others. I rough turn all my work and let it cure. This can be no more than stress relief on dryer wood to major water loss. I turn rough to about an inch up to 12 " dia and about 1 1/2 " above that. Again keep in mind how wet the wood is and what kind of wood it is. As you work with your native wood you will quickly learn their characteristics.
And, welcome to our group ! Your wife is now an official turning widow. Please put your name on the frapper map.
Good turning and be safe
Bill in Casa Grande, AZ.
WOW, thanks for the quick replys!
Paul2
>It's good to know that using the grinder is OK, at least in the short term; I do plan on getting a replacement wheel shortly.
As to your comments on the bowl bases, they do make a lot of sense. I'm glad to hear that rimmed bases are better, because they do look a lot better.
Many of you mentioned roughing out the bowl and waiting a while before turning the base. Last weak I glued up some scrap pieces of mahogany, maple and walnut, all were several years old and fairly small, so they should be dry. Now if I turn them into a bowl, how long should I wait to rim-out the base? It is going to be a small, simple 6-7" bowl about 2" deep (humm, I guess that really makes it a dish).
Thanks again,
Paul
