Question
Question
Question
Bob Fawcett
>Who wet sands turnings?
If you do, what do you use as a lubricant and why?
Do you wet sand on the lathe?
Re: Question
Re: Question
Peter Hyde
>I have recently become a convert. I use shellac to firm up really punky wood and found that wet sanding was the way to go. I use a 50/50 mix of pure turpentine and boiled linseed oil. Do it on the lathe and go through all the grits to 600. Buff dry with clean paper towel and the allow to dry for about a week before finishing with wipe on poly or oil. Warning paint thinner or varsol leaves a white residue especially in worm holes! Turpentine is good. I tape plastic over all the vital parts of the lathe before sanding. Hope this helps.
Peter
Visit my site at:
http://www.oldtoolsshop.com/Galoots/pHyde/
Re: Question
Re: Question
Bob Fawcett
>Thanks Peter
Re: Question
Re: Question
Allen Neighbors
>Bob, I wet sand on the lathe. Slow rpm, and take my time. Grits: 220, 320, 400, micromesh (don't remember the grits on mm). I use either Danish Oil, or Lemon Oil, or Mineral Oil, depending on the piece, and I have used just plain water quite a bit, too.
I have a cloth throw that I throw over the lathe bed to keep the gunk off the ways. I have a jar of lacquer thinner that I put my jaws into occasionally to get the gunk off them. So far, I haven't had to strip clean my SN2s. Hope this makes sense. :o)
Re: Question
Sometimes
Barbara Gill, Remlik VA
>When I do, I use the finish of choice.
Re: Question
Re: Question
Bob Fawcett
>Allen,
Do you put any other finish on after wet sanding?
I have it in my mind that another finish won't "stick" after using an oil. I know this is wrong, but I guess I spent to much time around cars. Paint won't stick to something with motor oil on it.
Re: Question
Brad Vietje
Often
Brad Vietje
>Bob,
I often wet sand things that are turned to completing from green wood in one go. These are usually transluscent thin-walled bowls and vases, and I wet sand them to get as smooth a surface as I can before they warp out of round. For many green turnings I use just warm water in a bowl, and rinse out the slush often. It is messy, but there's no dust (that's the slush), and its easy to place a sheet of plastic over the lathe -- clothing is another matter. By wet saning, I mean applying and re-applying the wetting agent often to keep the wood wet -- this can help prevent the piece from warping until you get through a number of grits. If there are worm holes and voids, these need to be cleaned out with a toothbrush, toothpick, or compresser before applying the final finish. In fact, these voids really ought to be cleaned out between each grit, but that's another matter alltogether.
After I use water up through about 320, I sometimes blot the thing as dry as I can, or even dry it a little with friction, before moving to wet sanding with 320 and 400 with an oil finish. In my case that's usually Craft Supplies' Urethane Oil. I've also used mineral oil instead of water for the initial sanding, followed by a few rinses with mineral spirits and then the wet sanding with a polymerizing oil. After a few days drying, I apply additional oil finish as necessary.
Luke Mann's use of oil finishes on green wood was written up in American Woodturner a few years ago. While the penetration isn't the same as in really dry wood, the oil acts to slow the drying enough to prevent checking in green-turned pieces, and the finish that results can be silky smooth.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Question
Re: Question
Allen Neighbors
>Bob, it depends on the type of oil, and the intended use of the piece. Usually, if I'm using oil, I don't have another finish in mind. If it's Danish Oil, it's usually the chosen finish; but - after sufficient drying time, you could apply the finish of your choice, however I wouldn't try to lacquer something that I've been oiling. Mineral Spirits or Lacquer thinner will do a job on oil residue, but it doesn't remove it entirely... there will still be a little residue that can surface when you'd rather it didn't.
Lemon oil won't ever really dry. I use it for some things that I don't intend to put a hardening finish on. If I want just wood, with a satiny finish, and a finish that I can easily reapply, and nearly 100% guarantee that it'll never crack... it's lemon oil. (I once saturated a dried-out, cracked open, oak cabinet with lemon oil, keeping it wet. Within a week or so, 1/4" wide cracks had entirely closed up. We keep it lemon oiled now.)
Re: Question
Re: Bob... Brad used that word... :o)
Allen Neighbors
>that I was looking for... polymerizing??? I think that's the word that means hardening, doesn't it? Thanks, Brad. :o)
