How much HP?
How much HP?
How much HP?
Gary B. in Central NY
>I'm a new turner, who bought an OLD Delta Miwalkee rockwell (HUH?@?) it's a nice lathe, about 11" swing,around 40 between centers....and came with an OLD 1/3HP motor which, as I was doing some ornaments today crapped out. What do I need to replace this with? Also has anyone had any luck hooking up a variable speed router box thingy to their lathe? Thanks for the info
Gary
Re: How much HP?
Re: How much HP? *LINK*
Bob Fawcett
>Gary,
The router speed control only works on a universal motor. Most lathes use induction motors, and the router thing won't work on an induction motor.
You might find a replacement motor at this link.
Surplus Center
Re: How much HP?
Re: How much HP?
>Bob is correct, the router speed controllers really don't work for the kind of motor you need. I would look for a 3/4 horse for that size lathe. I've seen many of them equiped with old washing machine motors but if you can find something totally enclosed you'll be better off.
Re: How much HP?
Bob
>nice link.....what type of motor do I need? do I really need a TEFC motor? that's not what was on it.....they had a nice 3/4 hp on that website for 20 bucks.....as taken from service......
Re: How much HP?
Re: Bob
Bob Fawcett
>TEFC - totally enclosed fan cooled.
I would say you want TEFC if you can find one in your price range. Totally enclosed to help keep the dust out, and fan cooled to allow it to run for long periods and stay cool. This is what most lathes dome with from the factory. If your motor is inside an enclosure, you could probably get away with another motor. If you take this route look for one rated for continous duty.
Re: How much HP?
Re: How much HP?
Dave Belser
>Gary I believe that I have the same lathe. I learned to turn on it 3 years ago. I set mine up with 1/2 motor that I got at a yard sale. The original manual for the lathe specifies a 1725 RPM motor, 1/3 hp for "light homeworkshop use, and for medium duty. For heavy duty work a 1/2 hp motor is recommended"
I believe that HP rating of electric motors was less standardized at the time the manual was written. I grabbed the yard sale motor because it was cheap ($15) and the right speed/HP. It has an open motor case and no fan.
In my experience, it was fine to learn on. But once I got into roughing a lot of green bowls I found that I could stall it easily. Once or twice I managed to use the lathe long enough and hard enough to have the motor's thermal shutoff kick in.
Anyhow, the up shot is that if you find a cheap motor with the right speed/hp then grab it. If you intend to use this lathe as your #1 lathe forever (or a long time) consider getting a TEFC surplus or used for a good price or if you really want to splurge go for a motor and speed control setup. If you know that you will be doing heavy work, get a 3/4 HP motor.
This lathe is a nice enough lathe that it's worth spending a few bucks on it unless you know that you will want more swing in the future.
You can find the manual on the old wood working machines site (OWWM.com) or I could send it to you if you would like.
- Dave
Re: How much HP?
Gary you got a lot of god information above
Don Henthorn
>but no one addressed your interest in variable speed. If you are tinkerer as I am you can add variable speed to your lathe with some expense and a little time. You would need to add a DC motor with a speed control. They are not cheap but they do a nice job. You can find them by searching the net. Some surplus places will have them as well. You would need to install the motor behind your lathe and probably build a box to protect it from sawdust as it will likely be open frame. I think that is correct. some one may correct me. By installing a comupter style fan ( not expensive) on the box so that the exhaust goes out the slot for the drive belt your motor will stay pretty clean.
Re: How much HP?
Oops: Again I pushed the send instead of the
Don Henthorn
>Preview button. Anyway, I did this to my little Jet after a post by Mark Kauder and it has worked out great for me. I would think the 3/4 HP DC motor would be adequate for your lathe.
Re: How much HP?
thanks everyone
>I just looked up my lathe on OWWM.com, it appears I have the 12" lathe, which they recommend a 1/2-3/4 hp. I'll see whatever I can get cheap locally, then decide. Thanks everyone
gary
Re: How much HP?
Is this a religious forum? ;^D
Ed Moore
Re: How much HP?
Another possibility *LINK*
Bob Fawcett
>Just saw this in a Penn State flier. No idea how well it might work.
http://www.pennstateind.com/store/tclvskit.html
Variable speed conversion
Re: How much HP?
it's funny,
>I went out into the shop after work, to replace the motor with a junk 1/4HP one someone gave me (I figured I'd run it till it died). When unscrewing the box on the OLD motor to get the wires out, I noticed the brushes weren't even. One was stuck in, so I yanked it out and the spring was very compressed....I proceeded to stretch it out , crammed her back in, and she fired right up. So, she may be good for a few more chunks a wood after all.
Re: How much HP?
Re: Another possibility
>Boy that's a really good price. I called jet and the VS motor itself was $176.
Re: How much HP?
Pressed the post key by mistake before
Don Henthorn
>I had a chance to make corrections. Even then I miss too much.
Re: How much HP?
Yes, but , Bob, the speed range on
Don Henthorn
>that unit is worse than the range on the regular or VS Jet. I can't see much advantage to a variable speed whose lowest limit is 500 to 600 rpm. The regular Jet mini has a lower limit of 500rpm. That is too fast to be of much use as far as I am concerned. The lower limit on my conversion is -0-rpm and I find the slow speeds very useful for several operations.
