Segmented Turning
Segmented Turning
Segmented Turning
Jeff
>How do you cut your segments? I built a jig for cutting them on the table saw but it does not adjust for different angles. Anybody use something that works good and adjusts?
Re: Segmented Turning
Bill Stehman
>Jeff,
I had a closet full of table saw jigs that I wore out and tired of making them. I now use the cheap Icra miter for flat segments and the Incra 2000 for compound. Once zeroed to your blade both are excellent with minor adjustments from time to time. I can send you pics of my attachments to them.
georgetroy
>For flat segments you can cut your miters close and then use a 12" disc sander. You will need to make a sliding jig and angles for the slide. Curt Theobald has a video out that tells you how to make. I highly recommend a jig for accuracy that can't be beat. GT
>Malcolm Tibbets book shows how to build the sanding jig. The advantage of the sanding jig and a bandsaw is that you can cut your pieces out of the wood with grain facing any way you want. This makes a more stable segmented piece and gives more choices on how you orient the figure in the wood. I plan to go that route when I have more time.
Right now I'm using a sliding table saw cutoff jig that I've built several times. This is the 3rd one I've built and definitely works the best. I'll take some photos when I get back from the store and post them.
Re: Segmented Turning *LINK*
Ron in Drums PA
>I use a compound miter saw and a sander to smooth the surfaces.
As John mentioned Malcolm's book is tops
book
>I guess I should write this up and post it somewhere so people can find it. This is not the perfect miter gauge. You still have to run a test on each angle but once you've done the test once you can reset it perfectly each time.
The secret is to make it micro adjustable and to add metal pins that you can measure from after setting the correct angle. I use a dial caliper to measure the pins to reset an angle.
I've also found that the length of the segment is just as crucial as the angle so I made an adjustable stop block so I can set the distance as well as the angle on the stop block. This supports the segments and lets me cut them very accurately.
To test it I made a bunch of 36 segmented rings and they all fit perfectly. Then I reset it and cut several 8 sided rings with 4 inch miters. It took a few tests to nail them both but now they are dead on and repeatable.
>Here is a detail of the miter gauge with the micro adjust. You can see the 2 brass pins that I use for my measurements and also the 0 stop when I need to use it to cut 90 degrees.
>Here is a detail of the stop block. I took the design from an adjustable triangle that I used in drafting. I can slide it for the proper distance and then adjust the angle so the cut off piece is fully supported. The one thing I haven't built yet is a quick release hold down. It's in the plans I just haven't had time to finish the design and build one.
oops no photo
Jeff
>Bill,
I have a incra miter gauge and have tried to cut the segments with some success. I would love to see your attachements.
Will Do - via email
Bill Stehman
John Bussom
>Bill, if your pics for attachments to the Incra are available to others I sure would like to see them.
Currently I use a homemade sled that has been working great for me but I am open to improvements, come summer time when I can use the unheated shop I need to get back on on doing more bowls!
Thanks,
John
Re: Will Do - via email
Jeff
>Great - I look forward to your email. jeffnreno@sbcglobal.net
Hey! many others might also like to see them.
Don Henthorn
