Red Oak Bowl
Red Oak Bowl
Red Oak Bowl
Cyril Griesbach
>This red oak bowl is 5" dia x 3 1/4" high. This is an initial attempt to add some surface embelishment to a turning and I sure wish I were happier with the results. I don't like oak much anyway so I thought I'd give the color a try on this one. However, when I buffed this piece, some of the (prisma marker) color spread into the open grain near the color band. What could I have done to prevent this other than working with a closer grained wood?
Comments and critiques welcomed.
Cyril
Re: Red Oak Bowl
Re: Red Oak Bowl
Mike Rubes, Apex, NC
>Hi Cyril,
That's note a bad looking little bowl. I think the blue makes it look basket like. I wish I could help with the prisma color marker seeping, but I have that same problem with open grained bowls. I have found that if I burn the outline of what I want to color and then color, they done run as much. To help keep the colors off the buffing wheels, I put a layer of Tried and True Varnish on the colored areas (usually the non colored areas as well) and let it dry really well before buffing. I still get color on the wheels, but it seems to leave more color on the piece than otherwise.
Good luck! I like the blue and black, it's a good look.
Thanks,
Mike
Re: Red Oak Bowl
Re: Red Oak Bowl
Cyril Griesbach
>Mike,
Thanks for you kind words. I'll try that varnish trick as I did get some color on the buffs.
Cyril
