200+ woodworking book reviews
First Picture - Wolverine Grinding Jig Base
Larry In Lima
>Well, this is my first picture post, so hopefully - it works. Today I finally got my Wolverine setup done. Bad picture, but at least you can see it. Here's a few details for anyone considering it, or "redoing" theirs.
The 3/4" pine on the bottom is about 22" x 8". The little 3/4" x 3/8" oak strips are there to tell me exactly where the grinder goes if/when I move it or take it somewhere with me. Also helps keep the grinder in place over the long term since it isn't permanently mounted. I used brass #6 x 1" screws in the oak strips since I already had them laying around, and #8 x 1" brass screws in the Wolverine jig for the same reason. I slopped some Minwax tung oil on all of the wood, my theory being that it'll be easier to clean and wipe up dust / dirt every once in a while.
For anyone who cares, the grinder I'm using with this is a Baldor 7306, 7" grinder. My wheels are about 16.25" on center (1" wheels), and that is where I centered the sliding arms on my Wolvering jig on the pine before I mounted the 2 of them. It came out pretty well I think, but nothing like the quality of stuff I have seen posted here. Any questions or suggestions, feel free. I know an 8" grinder might have been better, but the price difference between 7" and 8" was a killer for me. Larry
Re: First Picture - Wolverine Grinding Jig Base
Suggestion...
Peter Teubel
>Your grinder should be bolted down to that base...and WITHOUT the rubber feet (if you grinder has them). In addition, should should at least DOUBLE the thickness of the board...or bolt it down to a study bench...or use baltic birch plywood. The Wolverine base must be absolutely solid otherwise you will get some vibration when dressing the grinding wheel...which will translate into an out-of-round wheel. I used a double thickness of 3/4" MDF for the base.
Re: Suggestion...
Larry In Lima
>Thanks for the tips. I can clamp the grinder down pretty solid when I need to, for dressing the wheels, as for the feet though - I have used it a good part of the day, and it doesn't move at all. The wood "edge" strips must be keeping it in place because it's not moving, or maybe I'm just not bearing down too hard on the grinder. Not sure. I like the idea on the double thickness of the base though, so might try that. Would make it a little higher too which would be a plus for me. Larry
Re: Suggestion...
>Peter I hate to disagree with you but I've had mine on a board the same size on the rubber feet and sitting on a steel stool. I know it's not the best situation but other than the stool being too low and occasionally having to readjust how it sits on the stool it works just fine. I won't argue that what you suggest is the ideal way I simply say that it's not a do or die situation.
Me, too!
Barry Turner
>I have had my Delta 8" Slow-Speed, 90-pound (think boat anchor) Grinder w/Wolverine jig in use for about three (3) years. It is not bolted down and is riding on it's rubber feet. It doesn't even have holes for bolts in its base. No problems to date. That grinder is so heavy, it's not going anywhere. Heck, I'll probably need help to move it anywhere else. Like John, I'm not disagreeing, just saying this works for me.
Re: Me, too!
Bob Fawcett
>For what its worth my Jet 8" which also weighs about 90 lbs is bolted to a 2" thick piece of Oak and a homemade stand. The stand is piece of 2 1/2" iron pipe welded to tire rim.
One reason I used the thick oak, my slide mechanism is also homemade. Its a piece of T track that rides in a groove routed in the oak. The T slot faces down and bolt with wing nut through the oak locks it in place.
