grinder tool rest
grinder tool rest
grinder tool rest
Steven Smith
>Does anyone have a favorite grinder tool rest? I looked at the Veritas - high quality but a little pricey for what you get I think. I would make one but someone wants to give me one for Xmas, just needs to know what to get.
Re: grinder tool rest
>My first choice is the Oneway sharpening system but I also have the Veritas and it's definitely worth the money. I originally bought it for planes and chisels and then used it to aid in turning tool sharpening for a long time. Eventually I bought the Oneway system which comes with a good flat tool rest as well as the V rest for sharpening some turning tools.
Bob Moffett
Bob Moffett
>I use the Wolverine system and really find that it does a good job.
Russ Babbitt
>I use the Vertas on my 6" grinder and the Wolverine on my 8". The Veritas is a nice and adjustable system, however I do not find it rock solid. I'd have to go shopping again to see if anything better is out there. The Wolverine is great, the whole system including the flat tool rest.
Re: grinder tool rest *LINK*
Dominic Greco in Richboro PA
>Steven,
I recently removed one side of my Wolverine sharpening system from one wheel of my grinder so that I could install the Veritas Grinder Rest. The Wolverine's tool rest "platform" was nice for sharpening scrapers and what not. But I couldn't use it to sharpen plane and chisel blades. Once I installed the Veritas Grinder tool rest, I found I could do all I used to do with the Wolverine's flat tool rest (platform), and more. I also have the Veritas Grinding Jig and Veritas Skew Grinding Jig. Both work perfectly with the tool rest and allow me to grind just about every chisel, hand scraper, and plane blade in my shop.
BTW, I didn't find it flimsy at all. In fact, since it straddles the wheel I found it very sturdy. Plus, I really like it's ability to be positioned almost any way I want.
I did leave the other side of the Wolverine in place. The V arm and it's associated jigs (fingernail grind and skew) are main stays in my shop. I use them every time I turn.
See ya around,
Dominic
"Modification" to Wolverine Jig
Steven Smith
>Thanks for the input. I appreciate you taking the time to respond. Veritas it is.
