Indexer on Powermatic 3520a
Greg Mitchell
>I am thinking about buying an indexer for my PM 3520a. I would like to know if anybody that has one ,do you like it, or is it in the way. how is it mounted. I have never seen one mounted, [opions are welcome]. I hade one on my nova and liked it. Is it worth the money or is there one better that would bolt on the 3520. Thank you Greg
Re: Indexer on Powermatic 3520a
Re: Indexer on Powermatic 3520a *LINK*
>Greg I've been using the indexer wheel you can buy from IronfireLLC. It mounts between your faceplate and headstock or between the chuck and headstock. I glued and pinned a block to the headstock to insert the pins into the indexer for alignment. It works better than I though it would. I can post photos of my mounting block with instructions on now I made it and mounted it. I thought I had posted it somewhere but can't find it. If you decide to go that route let me know and I'll send you the plans.
http://www.ironfirellc.com
Chuck Engstrom
>Hi Greg -- I bought my 3520A second hand and it came with the one shown, which seems to be the one sold by Powermatic through, among others, Osolnik Machinery (see link). The stopper screw shown in the link seems to have been lost along the way but my photo does show how it's mounted on my machine, on the back of the headstock over the motor, so it's not in the way at all, and in fact serves fairly well as a grip to turn spindle by hand.
PM 3520A indexer on Osolnik Machinery site
Norm Smith in Nova Scotia
>Greg, I have the Powermatic indexer and find it to be a pain to use. I ended up making my own. I like the one that John is talking about.
Norm
>Greg I'm working on a design for one that fits between the handwheel and the headstock. I just haven't had time to build it. I will probably build a simpler version to go on my Jet mini very shortly. I will post photos. I did make a version for the Jet mini that is more complicated. The wheels are easy to make, I use plastic or aluminum for stability. It's the latching mechanisms that get more complicated. Mostly because you want them out of the way when no in use. Below is a photo of the one I built for the Jet mini.
powermatic index block
>Here is the index block for the Ironfire index wheel. I used a 3/4" square block that was tapered to match the shape of the headstock. I carefully drill the index block to match the holes in the wheel. I drilled one hole and inserted the index pin. Then I drill the other 3. Then I drilled a 1/8" hole in each end for a roll pin. In the photo I put a screw in one end but it's not necessary and a pain to tap the threads. I've since installed one on another machine and we just used 2 1/8" roll pins.
To install it and drill the holes for the pins I used double stick tape on the backside. Then I put the index pin and a drill bit in the index wheel and index block. Install it on the lathe and stick the tape down. Now pull the wheel off and drill 1/8" holes through the lathe headstock. Insert the roll pins and your done.
I thought this wheel was kind of chinsy when I got it but I'm amazed how well it works. For other lathes you will have to come up with your own index block system.
Re: powermatic index block Picture
Jerry Hall
>FYI: John Lucas was kind enough to send me the picture (below) of his index block with the Iron Fire wheel. So it is posted here now for the record.
