We value your privacy.
>There is an article in American Woodturner by Phil Brennion on making a turned salt box. In the article he shows a flute down cut. This has confused many people. I hope these photos show the cut. It is a very safe cut for cleaning up endgrain. It is a bevel rubbing cut, not a shear scrape. give it a try. The start of the cut can be a little tricky but once it gets started and the bevel is rubbing it's very controllable.
>You are correct. Cutting endgrain with the long piont up is really tricky. You better be good with the skew before you try this.
I prefer to cut with the long point down. I usually start with the tip above center and arc in like using a parting tool. You have to rub the bevel of course.
If you want a really clean cut, necessary when turning things like spalted maple end grain, cut from below the center line with the handle really high. This is a very easy cut and if you use light pressure will leave even very nasty wood slick as a baby's butt. Don't know how slick that is, I'll have to ask Micheal Jackson. Oooh that's bad.
>I use that flute down cut all the time. Never having had anyone to show me what I should or shouldn't do, I have tried all sorts of stuff and in the process discovered many things that work and quite a few that I should have had better sense than to try! LOL Most of the disasters were with the skew, BTW.
>"If you want a really clean cut, necessary when turning things like spalted maple end grain, cut from below the center line with the handle really high. This is a very easy cut and if you use light pressure will leave even very nasty wood slick as a baby's butt."
John, am I correct that you are still describing the skew cut with the long point down? Thought I would be sure before I give it a try. Thanks.
>I look back at some of my early pieces and wonder how in the world I did them with the skills I had. I think I didn't know that I couldn't do it so I did it anyway. does that make sense? Actually you hit on a very good point that I try to teach. That is, I take every tool and try to see how many different ways I can use it. A good example would be the parting tool. I use it like a mini skew to turn beads, shallow coves and sometimes to finish off the bottoms in a skew like cut. Oh yea I do use it like a parting tool also.
>I use this a lot. Unlike the skew (handle high and long point down) I use the bowl gouge with handle as low as possible, and tip up. This is also a great way to make very smooth catch-free cuts with the traditional straight-across English grind on a deep bowl gouge.
I also learned from Robert Chapman about using a bowl gouge in this fashion on the inside of shalllow bowls, and especially plates and platters. For end grain pieces that are shallow enough you can make a fantastic cut from the center outward toward the edge -- nearly impossible to get a catch except when starting the cut from the outer edge in.
