Bleaching wood
Bleaching wood
Steven Antonucci
Bleaching wood
steve antonucci
>In reading the instructions, it seems like part A & B should be mixed then applied on the wood bleach. While it lightened the vases, it was nowhere near as white as expected.
Upon rereading the instructions, it also appears that I can apply A, and then B later to Neutralize.
Anyone familiar with two part wood bleaches?
Steve
Re: Bleaching wood
Steven Antonucci
Forgot to add...
steve antonucci
>How deep does the bleach go? Can I sand after bleaching without destroying the effect? Seems to have raised the grain a bit.
steve
Re: Bleaching wood
Re: Forgot to add...
Jennifer@Indy.USA
>Hi Steve,
I use the two part stuff and have found that applying 3 to 4 applications is where I get the best (whitest) results. Prior to that it's just sort of a yellowing effect. Also I've found that sitting the piece in direct sunlight gets you a whiter bleach too. I've never use the A/B solution to neutralize? I use vinegar and a cotton swab to do that. The porosity of the wood will determine how deep it goes. I usually just knock the fuzzies off...don't really sand again too much.
Hope this helps!
Jen
Re: Bleaching wood
Re: Bleaching wood
Allen Neighbors
>Steve, I've used the two-part bleach kit on a large German, Oak Cabinet. I put on the part A first, and allowed it to do it's work, which was not enough for my taste, (I can't remember the amount of time, but I just followed the directions on the container), and I believe I applied it two or three times. Then I used part B to neutralize the bleach, as a final step, so it would stop working.
Jen's right about the light. Bright light will enhance the lightening effect of it.
I sanded the finish beginning with 120 (I think) and went thru the grits to 320. You won't sand too deep to damage the effect of the bleach kit. You might sand too much for the patina, but not the bleach.
HTH.
Allen
Re: Bleaching wood
Re: Bleaching wood
>I agree with both although I try to raise the grain and sand before I start. If you start with anything courser than 220 you risk sanding through the bleach. It penetrates differently on different parts of the wood. Bleach also reacts differently with different woods, sometimes even changing the color. Fortunately on most woods it does lighten the existing color.
Re: Bleaching wood
Re: Bleaching wood
Gary Ljostad
>Steve the bleach I use says to mix equal parts of A and B apply and let work for a couple of hours. Next if it still needs lightning apply part B and again let sit. If more lightning is needed apply equal parts of A and B again. On my last bleached piece I repeated the process 5 times to get a very white wood. Neutralizing is done with a vinegar and water mix.
Re: Bleaching wood
Re: Bleaching wood
Ed Heuslein
>Howdy Steve: I've bleached quite a bit using the 2-part bleach. I've found that just mixing equal parts of A and B, and using several coats - allowing each to thoroughly dry between coats - works as well as anything else. The mixture goes a looong way. I use an old shot glass and cotton swabs and/or Q-tips and nitrile gloves and safety glasses. I've neutralized with vinegar and I've just let it go without neutralizing. I've noticed no difference once the wood is dry. I usually sand after the first coat with 600g to get the fuzzies off and have no problems after that. Several coats are required, depending on the type of wood. For instance, walnut and mesquite both bleach beautifully but require about 6 or 8 coats. Some others require less. Remember this product is very strong solutions of Peroxide and Lye, one in each bottle. Good luck.
Re: Bleaching wood
Re: Bleaching wood
Joe Flemig
>Steve,
Bleach is mixed, then applied - equal parts. You need to let the bleach application DRY COMPLETELY, before applying the next coat. The bleach works in the drying process. Sunlight just causes it to dry. If the wood is still damp from the bleach, don't apply more. You will accomplish very little.
I can bleach madrone burl (very reddish wood) to dead white in about 5 to 6 applications.
Joe Fleming - San Diego
Re: Bleaching wood
Steven Antonucci
Thanks all!
steve antonucci
>I guess that I was just expecting too much from a single application. I will take a few more passes at it over the weekend and post the final results in the future.
Steve
Re: Bleaching wood
Re: Thanks all!
Joe Flemig
>Steve,
While sitting on the man-throne this morning, I read the current issue of Woodsmith's article that talks about wood bleaching. It said that either mixing OR A-then-B application will work. If you mix, however, you have to use it up because the potency goes away with time.
