Delta lath noise
Delta lath noise
Delta lath noise
jack dolan
>My delta 46-700 varible speed bench top seems to be very noisey
in the pully area. Any suggestions on reducing the noise will be
apprecited.
Re: Delta lath noise
RP
>It usually means the Reeves pulleys are loose or your belt is trashed. You have to demanufacture the plastic stuff off the headstock to reveal the pulleys. Look around in there and you'll most likely see the marks of where the pulleys used to be or the tailings of your belt that is comming apart. It isn't hard. Just messy.
jack dolan
>Opened the housing and found out the lower pully was out of line. Made the adjustment and the noise was gone. Many thanks for your input.
