Looking for sandpaper - Believe it!!
Larry In Lima
>Ok, something so simple right? Well, I used to get all my sandpaper locally, but the place stopped carrying anything decent quality, and no finer grits at all.
I went to the Klingspor website, because so many people seem to use them, but didn't see any garnet type paper in any of the finer grits.
So what's a good source for some good quality paper in sheets? I bought some sandpaper locally, foreign made judging from some lettering printed on the back of the sheets that I can't even read. It doesn't hold up, and sure doesn't "cut" the wood much at all. Have to work twice as hard to get the job done.
Thanks - Larry
Re: Looking for sandpaper - Believe it!!
Darryl Hansen
>Industrialabrasives.com You can get a 1 meter x 36" for about $15. Good stuff. If you cut your own a 3" disk will cost about 9 cents or so. Their Rhino back is really good stuff.
Dick Hines
Dick Hines
>If you have a Home Depot of Wood Craft near you pick up some Norton 3X. Best sand paper on the market.
Also check out this sight.www.VincesWoodNWonders.com. I have used some of his disc and they are great. I don't know if he has sheet paper or not.
Terence Rice
>The 3X from 3M is the best sandpaper I've ever used.
I agree Norton 3x and Vince
Finkat *LINK*
Hooligan
>Is the best that I've gotten my hands on. I like Klingspor as well, in the stearate, and the wet/dry.
The finkat, though, seems much more uniform and lasts considerably lnger than anything I've ever had.
Finkat Paper
Jennifer@Indy.USA
>John, he has 1" strips now.
Bill Hale / Woodspinner
>I use the Klingspore J Flex. Wet or dry and to 600 grit.
I buy the 3 in x 25 meter rolls.
They are getting a little picky now and you will have to set up an account with them in order to place your order. ( No big deal )
Bill in Casa Grande, AZ.
Larry In Lima
>Thanks everyone, this gives me several options to check out. Will definitely be stocking up, because I'm getting down to about nothing. Larry
>OH good. I love the 1" stips. I still haven't built my sanding center but when I do it will have a rack for narrow rolls. I hand sand a lot since most of my projects are smaller. The narrow rolls are just so convenient.
Re: Finkat
>I tried this paper and it's my second best choice. The reason I don't like it is the backing. It's very flexible and is great for sanding carvings. I find the backing is so flexible it tears easily and for that reason doesn't hold up as well as the Norton. It does leave a very good finish and will cut your sanding time over using anything I've tried from Klingspor.
John Leonard
>I agree the Norton 3x is the best. It is available at Home Depot and thru Craft Supplies. Lowes carries a 3M product that looks similiar to the Norton 3X but is not nearly as good. John L.
Re: Finkat
Hooligan
>Very true. I tend to use it for sanding beads and finish hand sanding more than anything else.
There is another brand that I have used, that I like very well, but can no longer find it. It was very similar to the Norton 3x, but a little more flexible. Sort of a compromise between the two. I don't know the name off hand, because I'd given up on finding it again.
Steve Lewis
>sandpaperworks.com is where I just ordered from and is the best price I have found anywhere.
