We value your privacy.
>I know it's been said before but when turning wood stay out of the line of fire if at all possible. I was roughing out an elm bowl about 13" in diameter and a large chunk of it blew out. Flew 18 feet across the shop and would have done a good job on my face. I know I could use a nose job but don't really want to do it this way.
>Yes I know what you mean. I was using a roughing gouge on a green piece of bay laurel about 5 inches in diameter. The whole cambium layer with bark came off and hit me square in the face. Right on the bridge of my nose. That was about 4 or 5 months ago. I'm still gun shy. Shoulda had my helmet/face mask on. BUT I was just roughing it .. AH Haw. You all should stay out of the line of fire and wear a face mask. I'm using mine regularly now.
>Can you tell this newbie/wannabie turner exactly what is the line of fire for a lathe? I've only turned a couple of things - in various wood classes - but I take safety very seriously, expecially after I tried to rip some lumber on a cross cut saw and sent the board flying across the shop. Luckily I was standing in a safe position and just dented my wall.
>When turning bowls and platters, the line of fire is usually in the direction of rotation. In other words if it's spinning directly toward you if something blows up it stands a good change of hitting you. If you can stand to one side of this line you will be safer.
Spindle turnings can come off also but they are generally smaller and less likely to do much damage. I was demonstrating on a lathe with a bad tailstock one time and the spindle came off 3 times. It walked up the tool rest and hit me in the shoulder, 3 times in a row. Didn't really hurt and was kind of funny but could have hit me in the eyes. I do wear eye protection, always.
>Powermatic does. We did a survey and couldn't find one single person who admited using it. I never even installed mine. Might save you but it gets in the way for just about everything.
>I've been trying to think of a good explanation of "the line of fire". How about, "Imagine what would happen if your turning instantly became twenty feet in diameter?" Or imagine you mounted a bowl that was twelve feet in diameter rather than twelve inches. Don't stand "in" the imaginary bowl. Or, what would happen if you put a really big weed eater head on your lathe and turned it on? Stay out of the way.
I was cutting spalted oak blanks and roughing them to cylinders one Sunday night. Got tired, but decided to do just one more. I put a piece on that was going to be about seven inches in diameter and 14" long. Right hand reaches for face shield and left hand reaches for switch on lathe. Except when you are tired, you get it back wards. Piece flew off and got me right between the eyes on the forehead. Only place to go on Sunday night was the emergency room. 29 stitches and $1250 later, I'm back home.
Put the safety gear on first and stay out of the line of fire.
I recently wanted to cut off some steel rods. I had some abrasive blades I have been saving for just such an occasion. I put one on my chop saw. Blade clearly marked for 5500 rpm. I still did not like it, so I put on my coveralls with a jacket underneath and my face shield. I cut about four pieces and thought it was going well when the blade exploded. Must have flown into hundreds of pieces. One of them thumped me in the chest, but did not even leave a bruise because of the padding. Lathes are not the only thing with a line of fire.
>Anything that rotates at any substantial rpm has a line of fire that is 90 degrees to the axis of rotation; it is centrifugal force. Many turners stand within this zone unnecessarily and depend on a thin plexiglass face shield to protect them. Any protection is better than none but a plexiglass shield is not going to do much good when a 20 lb hunk of wood comes at you at a speed we don't even want to think about. The biggest safety rule is "don't be where the flying pieces will go". This is why I prefer to turn bowls and hollow-forms outboard. Many also depend on a safety guard that may have come on the lathe when it was purchased. Note that this guard only stops things that are going away from you or it may cause the piece that was going away from you to bounce back into your face. You should also turn your lathe so that it is not in line with a near wall which might bounce a piece back into your face. Now if you are doing a demo in a crowd then the safety guard might protect the crowd although it will not protect the turner.
The space between the "wires" of the guard is large enough that a piece flying through could still do significant damage. Staying out of the line of fire is the best advice.
