finial advice please
ken chase
>I guess the wood was still too green and the point on my finial is bent a bit off vertical. Is there a remedy?
Thanks
Re: finial advice please
>I'd have to see it to make a better guess but you might be able to steam bend it back. I'm sort of assuming that it's not just the very point but the shaft leading up to the point. Wrap a piece of cloth around the area you want to bend. Soak the cloth by running really hot water over it. You may be able to bend it this way. You'll probably have to figure out some way to clamp it in the new position until it dries. Depending on the wood you may have to clamp it slightly beyond where you want it due to springback.
Ron in Drums PA
>Is the finial attached?
If not, it may be easier to just make a new finial.
