Robust update
Robust update
Robust update
Ed Moore
>As some of you may remember, my Robust 25 x 28 arrived near the end of September. I promised that I would write a review after I had some time on it. There are still some things I need to do before I feel that I can write a comprehensive summary, but I think it is time for me to tell what I do know.
1. The Tilt-Away Tailstock feature is worth its weight in gold. I have been making thin-stemmed goblets and after rounding the stock between centers I put it in a Vicmarc chuck with shark jaws and then rotate the tailstock out of the way. My elbows applaud every time I do this and I smile a little. ;^D
2. The spindle-lock is convenient and easy to use. Knowing that I can't start the machine when I might forget to disengage it is very comforting. As many of us who have A^3D^2 (Age-Activated Attention Deficit Disorder) I like this feature.
3. When the lathe is plugged in and the switch is released you start the lathe by turning another switch clockwise or counter-clockwise. CW is forward and CCW is reverse - no switch to set, just decide which way you want the spindle to turn and twist the switch, which returns to the neutral position.
4. I'm about to do some heavy work, coring some 24" red oak blanks. I'll get back to you on that after I have some experience.
5. I like the quiet and steady operation of the lathe. The alignment is excellent and when I take a spindle from between centers and put it in the chuck it is as if it was rounded in the chuck originally.
Opinion after two months: I am EXTREMELY HAPPY with this lathe. I made the correct decision for me and would recommend a ROBUST to anyone who wants a quality lathe. I'm a happy camper!
If anyone is considering a ROBUST and wants to test-drive one, you are welcome to come here and try this one. We are SE of Roanoke, VA.
Ed
Re: Robust update
Re: Robust update
georgetroy
>As another Robust machine owner, I agree with all of this. Ed forgot to mention the no rust bed of stainless steel. He can turn all the wet wood he wants without a lathe blanket. I have adjusted the height of my lathe 3 times now to make it just perfect for me. Try that on some of the other heavy duty machines out there. The moveable headstock is the way to go, work off the end like I do, my turning life is so much easier. The remote control can be place right where you want it instead of looking up in the sky or down at your feet. Yes it costs more bucks to go first class with the best USA made lathe out there. GT
Re: Robust update
Re: Robust update
bowlman
>Is there a link to the Robust lathe?
Re: Robust update
Re: Robust update
Phil Powell
>www.turnrobust.com
Re: Robust update
Tease!
Jennifer@Indy.USA
>Glad Roburta is treating you well, Ed.
If I lived closer I'd love to take a test spin!
Jen :)
Re: Robust update
Then I wished that you lived closer!
Ed Moore
>Carolyn and I would be delighted to see you and have you test out Roburta.
Ed
Re: Robust update
I'm glad to know that .....
Jamie Donaldson
>... I'm not the only wierdo who named his lathe!
Re: Robust update
You are not the only weirdo!
Ed Moore
>I'm sure of that. Miss Jen did the honor in this case and my lathe is dubbed Roburta.
Ed
Re: Robust update
But is she Roberta Robust or Robust Roberta!!??
Jamie Donaldson
Re: Robust update
OOOoppp!! Roburta??
Jamie Donaldson
Re: Robust update
Studly gonna meet Roburta??
Jim Swank
