Rockwell Delta lathe
TiO
>Can anyone tell me anything about this lathe? Like its vintage or model Number?
thanks
TiO
thanks
Re: Rockwell Delta lathe
Frankster
>That is a Rockwell 3400 lathe. I have one just like it. Four speeds, without a taper in the headstock arbor but with a 7/8" x 14tpi thread. #1 Morse taper in the tailstock. Some parts are still available but rare. Good solid machine to learn on.
Hmmmm...
Brad Vietje
>Frankster may be right, but I suspect he's jumping the gun a bit based on that one little photo. There are quite a few Delta/Rockwell models from the 50's and 60's that look pretty similar.
Terry, I'd want to know if all you have is a photo, or is this a machine you can inspect in person ? Does this have a hollow spindle, or a solid one ? There are a few look-alike models with a gap bed and a 1" x 8 tpi spindle with a #2 Morse taper... I'd want to know more. I learned on one with those features, but a lighter duty tailstock. This one looks a little beefier, so I'd suspect a larger spindle nose than 7/8 - 14. Frankster may be exactly correct, but I bet there are a few other models that look pretty darned similar.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Hmmmm...
frankster
>Guilty as charged! And a little trigger happy.
Re: Rockwell Delta lathe *LINK*
Jim
>I've got one suspiciously "simular" in my shop...
The Old Wood Working Machinery website is the best place to look. As has been said, there are several models, and look alikes out there.
Old Woodworking Machinery
