anoying noice on a pm3520b
miguel
>I have recentlly bougth an incredible lathe, a pm3520b, really the best bang for the buck, about a month ago I noticed an anoying noice in every revolution specially in the low rpm, I know there is a tread about this and they all have an intresting and long ways to fixit,someone even called the pm technitian (for me it is out of the question I live in monterrey mexico)and I just solved the problem and so simple and fast that I want to share with all this fine and intresting people called woodturners. the problem is in the block that holds the spindle when you push the black buton to hold tight the spindle just take of the buton removing the screws and plate and troughout the hole find the block opresors and with an allen key tighten them (they are two one oposed to the other)and the noice stops.have a nice thanks given day
from monterrey mexico
Re: anoying noice on a pm3520b
Good tip.
Don Henthorn
Bienvenido!
Jorge Castaneda
>Miguel,
Thanks for the tip, hope you become a regular contributor to this fine forum.
Let us see some of your work.
Thanks
Jorge
Andy DiPietro
Re: Thank You, Thank You
Andy DiPietro
>That was exactly the noise problem on my 3520B. Not only was one set screw loose but the second one fell out and I found it between the housing and two of cables. No more low rpm Noise!!
>Good tip. You should submit it to the AAW messageboards. They have a Powermatic tips section. http://www.woodturner.org/vbforum/index.php?
It's under the tips and techniques section.
eliot d
>Does anyone know if this is also a problem with the Powermatic 2530 A ( the A, not the B) ?
Dick Hines
Dick Hines
>I have had the same trouble. I cut the long end of an Allen wrench off and use a big set of pliers to tighten the screws. Then I dropped a little AC on the screws.
georgetroy
>You could also post this information on the Powermatic group on MSN.
http://groups.msn.com/PowermaticLatheOwners
Jerry Whitaker
>Miguel....When are you heading back north across the border? When you do, come back and see me. I still live in the same place.
