200+ woodworking book reviews
rebuilding Powermatic remote start
>My Powermatic 3520 remote switch died this weekend. It had acted up several time in the past. I don't hardly ever use it so I was a little hacked. Fortunately it was an easy repair. Woodcraft also sells a remote switch that appears to be very similar to this so maybe this will save someone some time.
Take the box apart and take the switch out. You'll have to push the little plastic latches on the ends of the switch toward the switch and at the same time push the switch out. That's by far the hardest part of the repair.
The switch is held together buy two plastic spring latches located on the sides of the switch. Pry these out and seperate the switch housing. There is a rubber dust cover. Pull this out. clean it off. It apparently doesn't work all that well because my switch was pretty dirty.
There are two plastic pins that push on the rocker arms. Don't lose these they are just floating in some holes. Pull the metal rocker arms out and clean them off. It only takes a very small amount of dust to keep this style of switch from working.
put them back in, correct side up. Now put the rubber dust cover back in. Then put the top part of the switch back on and snap the plastic springs over their clips. Put the switch back in its box and put the box back together. Not a difficult repair at all.
Re: rebuilding Powermatic remote start
Andy DiPietro
Andy DiPietro
>John,
As you already know my switch died this weekend too. It is just over a year old and WMH Tool will not replace it. I use my remote all the time because I mostly turn hollow forms. When hollowing, dust drops right on top of the switch. I will give your cleaning procedure a try. Yesterday I ordered two switches from Grizzly, Model #'s G8988 & G8990. This way I can change one on the fly. The G8990 is an upgrade switch with sealed buttons for $9.95. The G8988 is the same paddle switch for $3.95. I will let you know how they work out.
>Andy I think I may take mine apart and put some silicone caulk around several areas to see if I can seal out the dust. I think a thin layer on both sides of the rubber dust guard will help. I may look at putting a bead around the hole in the rubber where the plastic pins go though. If this won't interfere with the movement of the pins is should help keep the dust out.
Ted Calver
Ted Calver
>Andy,
My remote suffered a similar fate and I also noticed the switches in the Grizzly catalog. I hope you will let us know if the Griz switches work. Cleaning didn't help with my remote, and I sure do miss it!
>If just cleaning doesn't work, check the contact points they may be pitted or have something stuck to them. The only other possibility would be if the plastic pins that are actuated by that stupid child proof switch are worn or the child proof actuator is worn or not seated all the way. (sorry those things annoy me and have caused me more headaches than the children they are designed to protect)
Jerry from Lapel In.
>Just put your switch in a large plastic zip-lock clear bag and no more dust problems.
Wilford Bickel
>Please remember to disconnect the power supply before working on any switch like this!!
Ted Calver
Ted Calver
>John,
Just wanted to thank you for this very helpful post. I had 2 inoperative PM switches, the original and the free replacement when the first failed. Both are working like new now. Your step by step instructions were enough to overcome my fear of frying when messing with lectric stuff. Thanks again
Glad it worked.
Re: Powermatic remote start
Douglas Amsbury
>Can one use a 110V switch on a 220V lathe. Aren't all/most PM 220V?
Doug
Russ Babbitt
>I do not have a Powermatic, but looking at the wiring diagram I would say yes. That is if your a talking about remote start only. That said I would wait to hear from someone with a Powermatic that might be able to give you the specs on the factory switch. My original Woodfast uses a very low voltage control line to the controller so I could use just about any SPST switch.
>I'll have to go measure but the voltage but the remote start only switches the variable frequency drive circuitry. On the units I've installed on other lathes this was 24 volts. Since I have the Powermatic switch I simply installed it and never measured the voltage. I'll do it this morning when I go to the shop.
>I checked. Mine is 24vdc.
