We value your privacy.
>I am wondering about height adjustment for these systems. Do you have it on your systems? Do you think that it is necessary or useful? I don't, but I was asked if I thought this was useful or not, and had never considered it before.
>I built mine so it would be taller than the tallest piece I could make on the lathe. I didn't take into account using the steady rest but for the most part I think it will fit around that. I've only used it once anyway, so far.
>Mine is home-made (though not by me), and there is no adjustment for the height of the laser arm. The only tangible advantage I could see would be a little less tuning fork sorta vibration that might be a little worse at full height than set lower for smaller pieces. These rigs are most accurate when the 3 axes are as true as possible, so the light comes straight down to intersect the plane of the cutting tip at a 90 degree angle. As long as you carefully adjust the tool rest height so you are cutting at dead center height, with the leser beam coming straight down normal to the plane of the cutter tip, spindle axis and tool rest whenever any precision is required, you should be fine. If the light is mounted a bit crooked, you can lose some accuracy even if you very carefully set the gap between light and cutting tip. The problem comes up when you are not cutting at center height, or when the laser is angled a little bit, because you will not be aiming the light at the widest part of the outside of the form.
Aside from a little better vibration control, I don't see much advantage in adjusting the height of the laser. BTW, laser light doesn't get dramatically dimmer (harder to see) at higher positions (greater distances) because it is not a diverging beam, like a flashlight. In other words, it won't be appreciably dimmer at 12" height vs a 6" height for a smaller form, because the light is in a coherent beam.
>Well, I wished mine had a variable height adjustment the other day when I couldn't use it because it would have banged right into the (large) hollow form.
>Madee mine on a slide, but I'm in the process of changing to a fixed height to reduct vibration at the laser head. Mine will be set so that the laser clears 21 inches off the bed.
