Sharpening a Bedan
Ron McKinley
>Just got a bedan and love it but it came with no sharpening instructions. So far, I've just been running a diamond hone across the the top (flat) edge. Do I need to do the same on the bevel edge? Thanks.....Ron
Sharpening a Bedan
Ron McKinley
Re: Sharpening a Bedan
>I've just gently honed the top edge and put the beveled edge on the grinding wheel.
>Ron I sharpen just like I do the skew. If the bevel needs to be ground I do it. 90 percent of the time I use various diamond hones on the bevel and top. If I've freshly ground an edge on the grinder I start with the puple or medium diamond hone and do the bevel. Then touch the top to take off the burr. Then I switch to the fine and super fine and do the same thing. I'll follow this with a leather strop that I rub with the green sharpening compound I get from Veritas. This takes very little time and makes it sharp enough to shave hair.
Thanks
Ron McKinley
>Thanks to both of you.......Ron
Re: John, I do my skew the same way..
>as it's the only way to get decent planing cuts. But why sharpen a bedan that way? I typically take it from the grinder to the honing wheel and then to the turning. (Which is also the way I sharpen my gouges.)
Maybe I'm using the bedan the wrong way. I treat it as sort of a combination overgrown parting tool and scraper. I'm getting to where I can roll beads with it and finess certain convex features.
>The bedan does make a good giant parting tools but it's specialty is to be used as a skew. It is really good if you want to turn a bead on top of a bead. Or a bead on a ball. You can do this with a parting tool but it's tricky.
