New Nova lathe (Nova 1624-44)
wilbur
>I was looking at the Woodcraft site today and found that they have a new lathe from Teknatool - the Nova 1624-44. It has a 16" swing, 8 speeds from 214 to 3600 rpm, a 1.5 hp motor, and a swivel head. best of all, it's $999. The length of the bed is short -- only 24", but there's an extension that will increase the length of the bed to 44", for a total of $1198.
For comparison, there's a Jet 16x42 lathe that gives you variable speed from 0-3200 rpm, and cast iron legs, but this runs $1799. Or $2099 - it looks like it's listed twice.
Does anyone have any thoughts on this lathe? It looks like a really good value.
Re: New Nova lathe (Nova 1624-44)
Ron McKinley
>I have the DVR XP and from what I tell the Nova 1624-44 is a very similar lathe but with a different motor arrangement. Teknatool makes a quality product but I've not seen any reviews of the 1624-44...Ron
Hooligan
>I ordered that as a backup, recently. I've been worried about my 1642 for a little while now, and it's been acting more and more strange as time goes on.
If it pans out to be what they say it is, and the quality of the other Nova lathes, I will be happy with it, for certain.
>Sounds very much like the lathe I used to have. I don't know if they are re introducing this lathe. It's a good lathe but not in the same league as the Jet 1642. My complaints were mostly the lack of rigidity. The Jet is noticeably more solid. It's not a bad lathe. I used it for about 4 years, turned a lot of stuff. I sold it to buy the Powermatic which is a lot better than the Nova but of course a lot more expensive.
Peter Teubel
>This is really v2.0 (so to speak) of the old Nova 3000 lathe...but with some improvements. More rigid bed, redesigned (stronger) tail stock, and reversible motor. It now includes a stand. You still have to change the speed manually by moving the drive belt in the stepped pulleys, but it has a nice range to cover almost any kind of turning.
Mike Stafford
Mike Stafford
>As Peter said this looks to be a newer version of the Nova 3000 which is what I turn on. I couldn't be happier with my lathe save the fact I would love variable speed and reversing capabilities. Otherwise I have found it to be a very capable and durable machine. When I bought mine used but still in the box (gloat) they were being sold for around $800 on sale. So $1000 is comparable I would say.
Re: New Nova lathe (Nova 1624-44) *LINK*
Bruce Wiseman
>Mike,
For around $400 +/- you can add variable speed to the 3000. I did it and it made a world of difference. I used the info on this excellent web site to do it.
http://www.theturnersshop.com/
Mike Stafford
Mike Stafford
>Bruce, thanks for the info. I have seen this site before but I fear I am too cheap. I bought my 3000 for less than the cost of converting to variable speed....I think I will buy a new lathe before I do the conversion.
Walt A
>Wasn�t the biggest problem with the 3000 that the motors shaft had a tendency to break close to the bearing? Motors from several high quality manufactures were falling victim to this failure. The 3000 shipped from the factory without a motor, each importer supplied the motor of there choice. Nobody can say for sure if it was a design flaw or operator error by over tensioning the belt. The first rumors about 1624-44 indicated that the new motor would have a larger shaft diameter. Teknatool site does not list the motors shaft diameter. Seem to me its going be hard to sell a lot of 1624-44 with so few improvements over 3000 and so many used 3000s showing up on the used market.
Jet 16x24 1.5 horsepower 1799.00
Jet 16x24 2.0 horsepower 2099.00
Walt A
>Walt exactly what happened to mine. I would lay odds on the fact that the shaft is flexed a little with every revolution of the wheel. This constant flexing leads to failure. I know I never put any more tension on the belt than necessary to drive it because I had heard that this might be the problem. I changed the motor to a 3 phase motor with a larger shaft and put a VFD on it. I sold the lathe to a professional turner and he is still using it without the motor shaft breaking.
