Jet 1236 Burned out motor
Ed Larson
>Yesterday was a bummer. I burned up the motor on my Jet 1236. I bought it used and I think (hope) is was due to old age. I have ordered a new motor. Has any one eles experienced a problems with burned out motors??? Is this a common experience?? I have just turned light stuff. I'm curious about the adjustment on the inside reves pully of the motor, it was running very close to the motor but not rubbing as far as I can tell. There was a gap of about 3/16 of an inch between the reves pullies when at the lowest speed I thought I read somewhere that the reves pullies should alway be engaged?? Thanks for any help.
Ed Larson
Re: Jet 1236 Burned out motor
Peter Teubel
>I had 2 of those lathes and beat the snot out of them. I mean, they were literally scrap iron after I was through with them. But never had any issues with the motors. It would run so hot that you would get a 2nd degree burn if you touched it, but they never skipped a beat. The reeves drive was always somewhat problematic, though.
Ron in Drums PA
>On my 1236, my reeves drive is very close to the motor.
I'm not sure what you mean by a 3/16 gap on the reeves drive. On mine, the splines are just barely engaged at the lowest speed.
Under the pulley on the headstock, you will see a shaft which is part of the speed control. Under this shaft there is a set screw where you can make minor adjustments to the gap on the reeves drive. Be careful that the shaft does not hit the headstock pulley when you are making your adjustments.
Hope this helps
Ed Larson
>Ron
On mine the reves drive on the motor are not fully engaged when at the lowerest speed, they are open about 3/16 of an inch. Thanks for the info on adjustments to the headstock side reeves drive.
Ed
Ron in Drums PA
>I was thinking, there is a chance that the belt is too small.
The size on mine is 3L 240 (metric)
Ed Larson
>Ron
Interesting, I just bought two 3L 230's and the Jet parts list shows that size. Did yours come with 3L 240?? Do you know the difference in metric vs. ?? the parts list does not say metric. I will write Jet and see what they say.
Ed
Ron in Drums PA
>I did get the belts from Jet.
I remembered that I did have a problem with the belt and the reeves drive when I first started using the lathe. Jet sent me a new drive and the 3L 240 belt.
Re: Jet 1236 Burned motor Good News
Ed Larson
>Good News
Hot motor + burned smell + thinkig the worst = burned out motor RIGHT??? WRONG!! More investigation + motor smells okay + look at switch = burned out switch GREAT NEWS.
I guess we have all been there. Now that I have committed $200 for a new motor I guess I can by 3-4 new gouges. Sounds logigal to me.
Thanks for the help
Ed
