Have a question? Ask Woody!
Platter Blank prep/rough out problems/cracks
Devon Palmer
>All,
I've been experiencing a 50% loss rate on my platter blanks. I've been cutting 2-3" thick disc's off of my bowl blanks to get a platter and a shallow bowl (stuff thats 14" and greater). It all comes from trunkwood and is "almost" quartersawn (off to one side of the pith). I mount the platter blank between centers and cut a slight tenon, put it in a chuck, and get it round and perfectly flat removing any remaining pith (and actually cutting beyond it at least 1/2 inch).
So, visualize a flat disc of wood, with a shallow 5" tenon on the back side. I wax this completely, throw it in a bag for 30-45 days (when its dry out Winter/summer) then pull it out and let it air dry for a year or two depending on the wood (usually maple, some poplar and a little cherry/black Walnut). During this time, I keep it close to the ground and out of a draft.
They typically split close to the center where the grain is longest, 2-3 months after they are roughed out. It doesn't seem to be related to the pith as its usually off to one side or the other. If I make them any thinner, they "potato-chip" out of shape so badly, I can't get a platter out of it any more. The larger the platter, the worse it tends to be.
What am I doing wrong? Do I just need to use bigger trees to get something that is completely quartersawn?
- Devon Palmer, Columbus, Ohio
Re: Platter Blank prep/rough out problems/cracks
Gary in Zirconia, NC
>I would go a little thinner. I think you will lose less due to potato chip effect then spliting. If their so thick they can't warp, they will split since they have to move one way or the other. Also, try a slight taper, then they can move inward without cracking. I cut mine so that the rim is about an inch higher then the center.
Brad Vietje
Brad Vietje
>Devon,
Although you are entirely to one side of the pith, I suspect not far enough away from it. All the problems are through the center because that's the part closest to the pith, where the wood has to warp around a pretty tight radius to shrink. Is it possible to use wood a little further away from the pith ? Do we need to mail you bigger trees? That could get a bit costly !
Good luck,
Brad Vietje
Newbury, VT
Gary Evans Tallassee, TN
>Devon,
Have you tried leaving some of them in the bag for an extended period, maybe 6 or 9 months? Seems to me that the wood is still way too green when you pull it out of the bag. Between the wax and the bag, it's not going to lose much moisture during that month or so that it stays in the bag. When you bring it out, the wax is not slowing the moisture loss sufficiently to prevent cracking. To really be safe, the moisture content needs to be somewhere around the fiber-saturation point (around 25% MC) before you subject it to air-drying stresses.
Gary
Steven Antonucci
Some things that help (I think)
steve antonucci
>First, I do exactly what you do with the pith "slab" of a large tree. I have knocked out some similar sized quartersawn boards, and I typically end seal them and then stand them up on end for a period of time. (Read this somewhere on a sawmill thread...) Apparently, it helps the moisture slowly leave through the end grain, and it has helped.
After a while, I will bandsaw my blanks and then bag them. If they still feel wet(cold against my cheek), I'll seal them. Has helped quite a bit in saving blanks the few times I've done it.
Steve
Re: Some things that help (I think)
Devon Palmer
>Ya Know,
Come to think of it, the few that I have leaning up against the wall, with the grain running vertically, haven't cracked.... I'll try leaving it in the bag longer as well and getting farther away from the pith.
Again, thanks all for the advice, you're the best....
- Devo
