glass bowls for goblets??
Robin
>I have a project that requires glass inserts(the bowl part) for goblets. I know Craft supplies has them, but I wanted to check other suppliers shapes and sizes. Does anyone know of another source? Thanks, Robin
Re: glass bowls for goblets??
Ken
>I have bought regular wine glasses and cut the stems off. Get a better selection this way. Also had best results with silicone(RTV) to mount them to the turned stems.
Robin
>What did you use to cut the stem off?
Robin
Barbara Gill, Remlik VA
>I have found that the glass goblets that are sold for adding a turned stem are not really nice quality; they usually have a rolled rim and are heavy as juice glasses. I too buy better wine glasses and cut off the stems.
I use one of those Dremmel blue stones and make a groove where I want the glass to break. I then go over to the heavy cast iron table on my old bandsaw, put the groove against the edge and tap sharply but not real hard with a piece of wood. The stem usually breaks cleanly, if not, I smooth the rough edges with the same stone. So far no failures out of about 40 glasses.
Re: glass bowls for goblets?? *LINK*
Hooligan
>I use these. They are base heavy, a tad, but they have the right feel and center of "grabity" when paired with wood for stems. They work very well, are crystal, and look very good.
I don't have any on hand right now, I'm sorry, or I would take a picture of some that I have done.
You can call PHG, and ask for Anthony, he's a good guy, and they ship accurately and fast.
(Not associated with them in any way, but like the product.)
Stemless glasses
>I also cut my own. We have stores here in the south called Tuesday Morning. You can get really nice goblets really cheap. I use the thin abrasive cutter on the dremel to score it before breaking. If I have trouble with them breaking I'll just cut all the way through with the same cutter.
I like having the little stems because it holds to the glue better. I use clear silicone caulking to hold them in place.
Jorge Castaneda
>Hi Barbara,
I used to "cut" bottles just by wrapping a string soaked in alcohol and lighting it, sometimes they just snap, sometimes had to dunk them in cold water, quite easy either way.
>I used to do that. We made ash trays out of gallon jugs. We would wrap string around the jug, soak it in lighter fluid and light it. The set it in cold water and watch it break right on the line.
