Response to All
>Sold the lathe; rack went with it so no more close-ups, but . . .
The tool rack swung from two points. The top "point" was a 5/16" bolt (with washers) that was set into the cross brace that picked up both of the top leg-set bolts for stability. The pivoting frame rode on a nylon washer and was secured with a cap nut.
The bottom pivot was just that; a 1/4" bolt and nut through a short piece of angle iron bolted to the bottom bolt on the one leg bracket point.
The angle iron was 7/8" stuff I had lying around. The top brace was cut and welded next to the pivot and then again at the rack to run the full length of the tool rack for rigidity. If I had tied it to a single point, the whole thing would have tended to rotate down and away. The long brace attached at a single point at the far end of the rack to keep it from sagging.
VERY IMPORTANT was to also incorporate a rotation stop on the top pivot point frame to prevent the rack from swinging into the spinning wood. Mine kept the rack a minimum of 12" behind the bed so it was never less than 6" from a workpiece, but always easy to get to and would swing out of the way if I was working with a long handle sticking out behind the lathe.
The rack was super convenient for that lathe because all the tools I needed for a piece could be loaded and held at arm's reach.
I found I didn't have a problem with the mobile base frame. You could, of course, do one of those "I" frames, but I had didn't feel the need to go there. The box carried 3 bag's worth of sand [230lbs]; the concrete blocks were optional.
Hope this helps.
