Re: Green Walnut Rusting Lathe - Problem Solved!
Steven Russell
>Hello Dave,
Been there, done that... Years ago when I first opened my studio, I was turning lots of green Red Oak. Texas Red Oak is one very bad, bad boy! I think it can rust your bedway before you can blink your eye. :-0 I was spending lots of time everyday cleaning up my lathe after a day of roughing and I decided enough was enough.
My solution to ending the problem was to make up some drapes for the lathe. My lathe drapes are a very simple and effective solution to protect the bedways from the wet spray damage caused by turning green timber. Before I came up with the idea of the drapes, I had tried various methods of treating the bedways. These included waxing the bedways, spraying them with oil, applying anti-rust sprays, prayers to the turning gods, etc. Some worked better than others however, I still had a looooooooong cleanup of the lathe after turning green timber for 8-10 hours. :-(
If you turn much, you know that some of the wet shavings can begin to rust the bedways very quickly or almost instantly. Also, the wet spray can cause damage to the tailstock live center and the exposed ram as well as the spindle threads and drive spur. I had tried spraying these as well, but the spray coating would not last very long.
I felt the only way to provide an effective solution was to prevent the water spray contact with the bare metal surface in the first place. Therefore, I fashioned lathe drapes that would protect the bedways from contact with the sprayed water and acidic extractives. The drapes are made from thick bath towels that have a heavy plastic sheet in between the layers and are doubled over and sewn in a geometric grid to stiffen them and prevent the top layer from flopping about. The drape is also treated with a waterproofing spray to provide additional protection. These types of sprays can be found in sporting goods stores or where camping supplies are sold.
I use two drapes, one over the banjo between the headstock and the tailstock and one behind the tailstock. The number one drape (over the banjo) protects the most critical area and keeps the mounds of wet shavings from contacting the bedways. Periodically, I will take the air hose and blow the shavings off both drapes whilst turning.
If I am turning *really* wet timber, I will switch out the number one drape with another dry drape. The number two drape (behind the tailstock) takes very little spray and never gets very dirty. A quick shot from the air hose to blow off the accumulated wet shavings periodically is all that is needed. I also spray some WD-40 under the number one drape as added protection from any spray that might wick its way through the drape (through the sewn areas).
Now, for the tailstock and the headstock protection... The tailstock ball bearing live center and the ram needs protection as well. I take a small piece of kitchen paper/paper towel and wrap it around the live center a few times. It should be long enough to cover any anticipated ram travel and cover the live center as well. I apply some turbine oil to the exposed (non-chromed) metal and then wrap the above towel around the center. I use a pipe cleaner to keep the towel tight and attach it between the center and the ram. This does not interfere with any ram travel that may be needed.
This paper drape is then sprayed with WD-40 on the exterior, for added protection. The headstock spindle is wiped with the turbine oil, as is the exposed surface of the drive spur. Because most of the action is on the other side of the blank, I usually do not apply a paper drape to the spindle area as the turbine oil provides very good protection.
These drapes are quick to apply (less than 10 seconds once a day) and have prevented 99% of the problems I encountered using other methods. My daily cleaning of the lathe is usually less than one minute! In the past I spent upwards of 30-45 minutes per day cleaning the rust, stains and gunk from the exposed metal surfaces.
I hope this helps to eliminate your cleaning hassles and helps to keep your lathe in pristine condition. Remember to check for free clearance between the blank and the drape before turning and be sure to sew it repeatedly to stiffen it, so it does not flop about. Good luck to you and best wishes in all your turning endeavors.
P.S. I turn on a Oneway 2436 and I notice that they now offer an option for stainless steel bedways. Too bad they were not available when I purchased my lathe!
Steven Russell
Better Woodturning and Finishing Through Chemistry...
