Bandsaw Help
Bandsaw Help
Bandsaw Help
Leslie S
>Does anyone know why a bandsaw that is designed to take a 93 and 1/2 inch blade will not accept a 93 and 1/2 inch Timberwolf blade? I broke the balde on my 14 inch Jet and wanted to repalce the blade. Darn thing wont fit!! Does Timberwolfe run short? GGRRRRRRR. Of course this happened when I had only two more blanks to round for a Christmas commission. Thanks in advance!
Re: Bandsaw Help
Re: Bandsaw Help
Ed Kelle
>I had the same issue with one Timberwolf, even though I had released all tension it was tight. I gave the upper wheel a tug down and found that it was slightly hung up. That additional clearance made the difference. hope this is helps
Re: Bandsaw Help
Leo Van Der Loo
Measure the saw blade to see what is out, saw or b
Leo Van Der Loo
Re: Bandsaw Help
Re: Bandsaw Help
Sean Troy
>I would say it's about a 99% chance the wheel hasn't released all the way down. Jet BS's are famous for this as soon as any dust gets in there. Tap the tensioning block in the back with a dead blow hammer after all blade tension is released.
Re: Bandsaw Help
Re: Bandsaw Help
Leslie S
>I finally found time to address my band saw problem. Many thanks to Sean Troy who suggested the wheel had not dropped. It hadn't and I was able to install the new blade and finish cutting up my stock for Christmas!!! Thanks again to everyone you all never fail me when I need help.
Re: Bandsaw Help
Re: Bandsaw Help
Ken Oakley-Sunny St. Cloud, Fla.
>Today I wanted to change the blade on my Delta 14" with riser block. I had a 1/2" resaw blade on the machine. I detensioned it and the blade was still too tight to remove. I put some oil on the grooves in the tensioning block and still couldn't get block to drop further. Then I tapped the block with a plastic mallet and it would not move. I looked in the hole in the rear wall of the upper wheel cover where the spindle for the wheel comes through and realized the lever or cam that adjusts the tracking of the blade was catching on the lip of the openining preventing the tensioning block from going any lower. I backed off on the tracking adjusting screw and KERPLUNK, the block drop almost 1/4". Maybe the tire on the wheel is getting so worn I had to keep adjusting the tracking and didn't realize it would cause the lever to catch on the housing. Put the new blade on, tensioned it and adjusted the tracking. Back in business
