REAL MILK PAINT
Jordon Shear Scraper- How do you Sharpen?
Andy DiPietro
Andy DiPietro
Re: Jordon Shear Scraper- How do you Sharpen?
>If it's really bad I put it on the grinder to regrind the 45 degree bevel. Then I use the plastic diamond hones to raise the burr. Most of the time I simply take the purple medium diamond hone and remove the burr by running it lightly across the top. The I run it up the bevel about 3 or 4 times to raise a new burr. I find that I can raise the burr 5 to 10 times before having to go back the grinder.
Andy DiPietro
Andy DiPietro
>That is a quick and easy way to sharpen the scraper. I tried the sharpened scraper on some torn grain and it worked very well. I then wiped on Tung oil on a dry and badly torn piece of maple. That worked very well too.
Thanks
eliot d
>After grinding any scraper, I always raise the burr by using a burnishing rod -- the way cabinet makers do with their cabinet scrapers. Actually , it's not one of those rods but rather a small angled pin held on a small platform. Veritas sells them, I think. The burr is smoother; on a microscopic level, the grinder leaves a jagged burr.
Andy DiPietro
Andy DiPietro
>I actually have both a burnishing rod and a Veritas jig. I did cabinet work for about five years before I got hooked on turning. I am going to try my stationary belt sander instead of my grinder for coarse sharpening. I think it will be easier to hold the scraper flat on a 6" wide belt the on a 3/4" wide wheel, at least for me anyway. Then I can experiment with the Veritas jig and the diamond hones.
Thanks
