Collar How-To
rj anema
>I've turned a dozen or more hollow forms and now would like to add a collar to one. Any hints on how to do it. Are there any links that show one or more ways to do it? Any help would be greatly appreciated.
Rich
Collar How-To
rj anema
Rich
Re: Collar How-To
Allen Neighbors
>Rich, get a chunk (stock) of the proper wood... denser is better... and round the stock. Make the chunk big enough so you can get several collars from it. You'll probably use up 1/2 to 3/4 inch of wood per collar... since I've made a few I now use about 1/2" most of the time... this includes parting off. Measure the hole in the form, and turn a tenon that will fit into the hole, and have the proper amount of lip/overhang you want (I usually have about 1/8 inch lip). But first, after I round the stock, the next step is the opening hole. I usually drill a 3/8 or 1/2 inch hole in the collar material of necessary depth to go through the collar, and not too much further. That way I can part off and the dimple remaining in the next collar is a starting point for the other bit.
I try to make the collar shape continue the shape of the piece, and then flair out a little near the opening. I sand and finish the top of the collar before I do the underside. I do all the underside with a parting tool. Don't forget to sand the inside of the hole.
I usually make the tenon about 1/8 of an inch long, just enough to stick down past the inside wall a little. When the outside is finished, I part it off, sand the bottom edge of the hole a little, and superglue it on.
Some folks make the tenon and overhang, part it off, and glue it in place, then turn the outside to fit the shape of the piece. I'd rather finish the piece, then make the collar to fit, and stick it on. That way I don't bugger up the edge of the collar when finishing the shape.
Confusing? I hope it helps you a little.
Re: Collar How-To
Wally Dickerman in Arizona
>I use a couple of different systems, depending on how large th opening will be. If the opening will be a couple of inches or more, the simplest way is to rough turn the piece inside and out, then, if it's wet, preferably let it dry. You don't want it to warp after the collar is on. When you're ready to finish turning the piece, true up the outside, then flatten and true up an area around the rim. Then glue on a piece of contrasting wood for a collar. Now, treat it just as if it's all one piece of wood. Shape the outside of the collar and finish turning the inside.
I'll enclose a pic of a piece that was done in that fashion. On that one, I inserted a piece of black veneer and a piece of holly veneer.
If I'm turning a piece with a very small opening I use a different system similar to what Allen described. That collar is added after the piece is finished inside and out.
Wally
Re: Collar How-To
>The turning is a bit over 10 inches in dia. and is Black Limba with a Wenge collar. The opening is about 2 inches
Wally
Re: Collar How-To
>I should mention that I use yellow glue for the collars like the one shown. For the smaller collars I use CA glue.
Wally
Re: Collar How-To
rj anema
>Thanks Allen and Wally, that will certainly get me started. I may be back if I get stuck.
Re: Collar How-To
Mike Brazeau
>RJ - Art Liestman has had an article on Collars for Hollow Vessels in the Spring 2002 issue of The American Woodturner and also in Canadian Woodworking, but I don't remember when. He credits learning the technique from Jacques Vessery. Could scan and email to you if you want. Send me an email if you want it.
Mike
Re: Collar How-To
>I have a tutorial complete with pics on WoW. In reviews do a search for collars.
Wally
Re: Collar Tutorial?
Ron McKinley
>I would really like to download your tutorial on Collars. Just went to WOW and did a search on collars in Reviews and came up with nothing. Also did a search on File Cabinet and nothing. I must have missed something. Thanks....Ron
Re: Collar How-To
Carole Valentine
>Do a search for collar (singular) in reviews
Same search in File Cabinet will get you
Carole Valentine
>Art Liestman's article.
Re: Collar How-To
Ron McKinley
>Thanks Carole but No Joy. Tried all categories in Reviews and nothing about collar. .....Ron
Reviews...Page 12...Bottom Line...
How about an invitation to WoW
Bob Fawcett
>I see I am missing a lot.
Re: How about an invitation to WoW
Brad Vietje
>I'm on it, Bob -- do I just remove the nospam in your address ?
Safe spinning,
Brad Vietje
Newbury, VT
Got It!
Ron McKinley
>Thanks Wally.........Ron
Re: How about an invitation to WoW make it 2
Frank of Mantua NJ
>can you make another invite.
Can I get an invite to WoW also? thanks
LT
Bob Fawcett
>Yes.
Just remove nospam.
Thanks.
Got it Brad Thanks
Bob Fawcett
WoW Invite For Frank and LT...
Brad Vietje
>Since I don't have complete names for you two, or an e-mail address for Frank, here's the best thing I can suggest:
E-mail the list owner directly, and ask for an invitation with your name and your e-mail address. His name is Herm DeVries, and he's a terrific guy. His contact is Herm@hdv.net. The invitation procedures have changed recently because some of the newcomers didn't read all the "rules of the road" and messed with the site's settings, so indididual members can no longer invite you directly. There are a few regulars on the WoW's site that have administration privleges, but I do not. That should get you in.
Safe spinning,
Brad Vietje
Newbury, VT
Re: WoW Invite For Frank and LT...
LT
>Thanks, Brad...I will contact Herm directly.
