Alcohol soaking - Goblets
Stephen Lewis
>I enjoy turning goblets. What is the procedure for wrapping the goblet in heavy paper for the drying period?
Would I just have to wrap the upper portion and let the stem and base exposed to the air? Thank you for any information. Stephen
Re: Alcohol soaking - Goblets
Brad Vietje
What wood ? How thin ?
Brad Vietje
Re: What wood ? How thin ?
Stephen Lewis
>I have been turning with cherry which has been air dried but I would like to try other hard woods. If I could turn them wet and use the alchol process without having them split, I would most probably live in my shop I have been turning them from 3.5in x 3.5in by about 5 to 6in high, small but neat looking. The wall of the cup might be 3/8th which is no problem with the dry wood. Should I use a thicker wall and then finish after the drying. Thanks
>Stephen I've turned a fair amount of green goblets. They don't usually crack as long as I don't leave the pith in them. They warp but don't usually crack. I don't do the alcohol soak. If your going to leave the walls 1/2" thick or more then it might be useful to soak them
Ralph
>Well, I'm no fan of DNA, but even then the rule appears to be leave it thick (10% wall thickness) and turn to finish size when dry.
Actually I am unaware of any process (boiling, DNA, LDD, microwave, air-dry) where you can turn to final dimensions, at least not without risking the warpage you get during the final drying process.
Allen Neighbors
>I made a goblet from green, wet, Cottonwood. Turned it to about 3/4" thick walls and stem. Soaked it in soap solution, and wrapped the entire thing in brown paper, but left the inside of the cup open to the air. Turned it upside down on a wire rack. It dried in about a month. I sold it last Saturday at a craft show.
Sorry, I didn't use the DNA for the goblet, but if I had I would have done it the same way.
Hope this helps.
After reading the previous posts, I may try to turn one to finish, from really wet, green wood, and see what it does... interesting. :o)
>Allen I turned the last ones from green cherry and the walls were about 1/8" at the lip and slightly more near the bottom of the bowl. Stem was about 5/16 at the top and tapered to a little more than 1/2. They were about 6" tall. One warped kind of funny where the stem meets the goblet. On the other one the base warped and had to be flattened. Neither one cracked. Took about a week or less to dry.
I haven't turned a thick goblet in a long time but I may do one this weekend just to see. I'll be in the shop most of the day tomorrow.
Stephen Lewis
>To all of you that took the time to answer, Thank You. The gemtleman who might turn a green, wet wood goblet, If you have a PIC of the finished product, Please let me see. Stephen
I haven't tried goblets.
Dave Smith, Longview, WA
>If you want 3/8" walls for the finished goblets then rough turn them to 1/2" or a little less. A 3" bowl will not distort very much. You can use the whole limb as long as the pith is not in the center. I have some very fresh vine maple I will try a couple of roughed out goblets and see how it goes. The maple is about 3" in diameter so I will be using the whole limb with the pith. I will let you know how it goes.
Dave Smith
Finally allowed back on the forums in Longview, WA.
Re: That'd be me, Stephen,
Allen Neighbors
>but it'll have to wait until after out Thanksgiving trip. :o)
I'll try to remember to turn one wet/green. :o)
Stephen Lewis
>Mr. Neighbors,
Thank You. When completed, Would you give me the wall thickness and stem thickness. Happy Thanksgiving, Stephen
Re: I haven't tried goblets.
Stephen Lewis
>Mr. Smith, Thats what I'm talkin bout. Wet and green,1/2" then finish to 3/8". No bith. Would you use the DNA procedure, paper the out side of the cup and turn cup down or what other process. Thanks. Stephen
