Bit off more than I can chew
eliot d
>I've gotten to a place in my hollowing where I seem to want larger and flatter. Most recent one is about 10 inches wide and only 3 inches deep. The hole is about 1 1/8 inches in diameter. I'm over my head. I can't see any way to reach the outside from the inside. Clearly I could enlarge the opening, and I probably will. I have several constraining rigs and numerous swan neck tools including JJ, Denis Stewart, and some home made ones, but nothing that will reach far enough. If I wanted to be stubborn and keep going, are there any methods to do this kind of hollowing?
Re: Bit off more than I can chew
eliot d
>Correction. It's 12 inches in diameter. and the hole is 1 3/8 in diameter.
Phil Joines Krum, Tx
>That's one of the problems with the comercial systems. You'll have to make your own bars. Draw a fulll size cross section of the shapes you want to find the shape of bar needed. One thing to remember is the farther the cuttet is from center the more torque there will be.
>Elliot I just went throught that and the project is not done, yet. My vessel is deeper than yours and only about 10" wide but the top is quite flat. I have a John Jordan tool that I made but won't quite reach the outer flat portion. I've bent a coat hanger trying to find the right curve and tool alignment. Now that I'm close I'm going to cut out a cardboard shape to the thickness of the tool and see if that will work. Once I get all this correct I am going to build a tool with that curve.
Like you I could just enlarge the hole a little and it would probably take care of the problem but I really don't want to do that. I was able to rough out the vessel with the tools I have but they just won't reach all the areas when I start to thin it out.
eliot d
>While I was thinking about the problem I had the following idea: one could cheat a little by hollowing the front face fairly thin and as far toward the edge as my tools would allow. Then, using the toe of a sharp skew chisel, cut out a circle that's large enough so that the rest of the inside can be reached with the tools I have.Then glue the circle back afterwards. I was thinking of holding the skew at an angle( in the horizontal plane) so that the slanted part of the kerf is wider than the tool kerf. That way there would be no kerf to fill. Of course, the piece would have to be smoothed down to blend the insert properly. Another possibility would be to allow a 1/4 inch or so kerf and fill with a contrasting wood "collar".
But I like your suggestions about mapping everything out carefully and making a tool that will do the job. I glad that somebody has thought about it.
>Elliot. A thin parting tool would work better. The piece will sink by about twice the kerf. You could try the technique on a piece of scrap to see how far it will sink. Then you will know how much if any to hollow the inside near the lip.
eliot d
>You suggestion makes a lot of sense; I'm going to try it.
>Elliot It's a lot like doing Intarsia. The angle you cut changes how far the wood drops down or in with Intasia, protrudes above the piece. I've used this technique to install plugs in the bottom of hollow vessels. The plug is thick enough I can get buy with just about any angle. I use a long thin parting tool and cut out a cone. Then I put this piece up to dry. I turn the vessel and let it dry and then trim the cone to fit. The grain matches really close.
Allen Neighbors
>Draw the profile of the piece... actual size... then check it out on paper, how much bend to put in a tool shaft in order to get the cutter to the thickness desired. Then make the tool to fit your captured rig.
Only way I know.
