? about Mahoney Walnut Oil
Scott Hurley in N. VA
>I'm making a salad bowl out of Hickory for a friend. I'm going to use the Mahoney Walnut Oil for a finish. I've never used it before, but it has a distinctly different feel than other drying oils (like Watco). The bottle says it's a "slow-drying" oil. How slow is slow in this case? How long should I wait between coats? How many coats? Thanks.
Scott
Re: ? about Mahoney Walnut Oil
Hooligan
>I soak my utility wares in Mahoney's, and let them drip dry, essentially.
Beyond that, I am a proponent of wet on wet with oils. I will coat it, let it sit about five minutes, another coat, let it sit another five, coat it....
Do this five times, then lightly wipe away the excess. Do the same the next day. Works well for me.
Rick Davenport
>Wow Hooligan, that's a thorough process.
I apply the Mahoney's, let it sit a few minutes, burnish it in with a cotton cloth while on the lathe, then apply the Mahoney's oil/wax mix, let it set for an hour and polish it with a clean cotton cloth.
I like the satin finish and it has held up well when I have used my bowls to hold salad, salsa or whatever.
R
Sean Troy
>I just apply, wait a half hour and apply another coat. Done. Why would you put any more than that on?
>I have an off brand walnut oil. I apply a layer let it sit overnight and then I apply the next couple of layers with 600 grit paper. It helps fill in some of the pores and gives it a better sheen. This brand is still pretty dull even after 4 or 5 coats and buffing with the Beal. Wish I new what it was but it was given to me. I think it's walnut oil from the health food store.
Bob Elliott
>Mike told me that he applies two coats only, then boxes the bowls up (wet) and sends them out to his wholesale customers.
Also, if you dig around on his website, it says he sands to 400 grit, mists the bowl with water, knocks down the fuzz with the 400 grit, then applies the oil.
