REAL MILK PAINT
high speed steel
high speed steel
high speed steel
Jeff Rich
>Does anyone have a source for high speed steel for tools?
Re: high speed steel
Re: high speed steel *LINK*
>Jeff I use old planer blades or I buy from Enco. I suppose there are a ton of places if you just do some searches. Be aware that you can't heat treat HSS yourself unless you have a pretty sophisticated heat treating oven.
http://www.use-enco.com
Ron in Drums PA
MCS
Check your
Terry Quiram, Roanoke Illinois
>phone book for someone that does industrial grinding. They may have some worn out, too small to use blades that will make excellent turning tools and scrapers. I did this and got some great stuff.
Jeff Rich
>Thanks for the leads!
I am also going to try some local steel houses.
I will let everyone know if I find a good deal.
