Box Elder HELP
Box Elder HELP
Box Elder HELP
Bill Hale / Woodspinner
>A friend from Canada just gave me three log biscuits and I am not sure how to cut them for best color. I piece is about 20 in. diameter and 12 in tall. The other two are about 13 in dia.and 14 in tall. The wood is from dead standing and is wet from beeing baged. There may be some spalting.
My lathe is a 2436. Remember AZ. is very dry.
Thanks Bill in Casa Grande, AZ.
Re: Box Elder HELP
Re: Box Elder HELP
>Bill I don't have a lot of experience with box elder but the stuff I've had the red usually runs in the direction parallel to the outside of the log. That's kid of a rough description but it gives you a better idea how to cut it. On my logs it's almost always been more colorful toward the heart so If your turning a bowl do so with the heart side as the bottom. Without seeing the wood this is just a guess of course.
Re: Box Elder HELP
Re: Box Elder HELP
Brodie Brickey
>Those are some nice sized blanks.
Keep in mind that box elder will loose the red flame if exposed to a lot of UV (sunlight). It would be best to use a finish with a UV blocker in it when you're done.
Smooth Turnings,
Brodie
Re: Box Elder HELP
Re: Box Elder HELP
>Knowing the color is with the grain would it be better to turn end grain on the two smaller pieces?
Bill
Re: Box Elder HELP
Re: Box Elder HELP
Jim Swank
>Or maybe the bigger piece? You'll get much bigger bowls from it that way if you can control cracking around the pith...
Re: Box Elder HELP
Re: The first thing to do is ....
Jamie Donaldson
>....rip saw them in half lengthwise following the pith- this will reduce the checking and allow you to start using and curing with the least amount of hassle. The center will start to dry more like the edges, resulting in more stable wood when you decide to use it. Don't forget to coat end grain with sealer. Does the wood smell like it grew over the septic field!!???
Re: Box Elder HELP
Brad Vietje
Re: Box Elder HELP
Brad Vietje
>Hi Bill,
What do you mean by "biscuits"? Are you describing full-diameter chunks (rounds) cut off the end of a log with the pith in the center, and the bark (or the outer edge of the wood if bark isn't intact) around the perimeter ?
If you have good color (?) it runs with the long grain, as John wrote. I have seen it forming a rough and ragged ring shape around the tree at a certain diameter from the pith. Usually a sidegrain shallow bowl or plate or platter shows the red streaking best when it runs along the inner bottom of the piece. I've made endgrain hollow forms that had good color in bands around the piece. The pic attached shows some bright red color in a band generally parallel to the bark surface on a few blanks. I turned the one in the middle and gave the burl in front to a friend. I guess I'd better find the other two !
Safe spinning,
Brad Vietje,
Newbury, VT
Re: Box Elder HELP
Brad Vietje
Re: Box Elder HELP
Brad Vietje
>Here's a closer view of the Boxelder Burl blank held between centers. BTW: the burl wood is very stable, and won't present much difficulty when drying in Arizona. Around here, a fresh-turned BE Burl piece can be dried near the woodstove with very little cracking, but nice texture. The straight grain portions are not so bad, but this stuff holds a lot of water, so you'll probably need to dry it pretty slowly -- bags will usually do, but if you turn a real treasure, I'd use Anchorseal or paste wax.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Box Elder HELP
Re: Box Elder HELP
bowlman
>Bill,
Really sorry to hear about your box elder predicament. I can tell you from experience that you're better off sending it to me to dispose of instead of worrying yourself sick about how best to turn it ... lousy wood anyway being a member of the soft maples. But, like I said, send it to me for proper disposition and to ease your Arizona sun stressed head.
Re: Box Elder HELP
Can I be your new best friend?
Hooligan
>I don't get Box Elder where I am at. At least not red. It's all cruddy blue, doesn't matter WHEN you cut it, or how long you wait to turn it. :(
Re: Box Elder HELP
Andy DiPietro
Re: Box Elder HELP
Andy DiPietro
>Wow!!, That is a beautiful Burl. Do you have a picture of the finished piece??
Re: Box Elder HELP
Re: Box Elder HELP
>Yes they are rounds. Where I grew up they were called biscuits.
Those Pics help a lot.
Thanks to all. Time to get the chain saw going.
Re: Box Elder HELP
Brad Vietje
Re: Box Elder HELP
Brad Vietje
>Andy,
Here's an attempt to post a pretty lousy photo -- this was with a borrowed camera (after mine was stolen) and an ad-hoc setup with a pearlescent silver vinyl background... I don't think I have any other photos of colored pieces from this batch of B-E Burl. This one was made from the cylindrical blank in the middle of a previous pic I posted last night. This piece is about 12.5" tall and 5" wide, all one piece, 5/8" hole and about 1/8" thick except about 1/2" thick at the bottom for a little stability.
The piece has faded quite a bit since this was taken (about 3 years ago) because a gallery owner had it on display close to a sunny window :-(
This was a real lucky find... a big 3-trunked tree that had split during a spring snowstorm, with one trunk that calved off the other two. I happened by (on a major road), and there it was, but largely hidden in the bushes. Funny thing, I saw this burl while working in the greater Burlington, VT area, on the very same day that I went to my first meeting of the Woodchuck Turners of Northern VT. I picked up well over a ton of wood and burl with a friend on the day of the next monthly meeting. When I went to retrieve it (with permission) we cleared the brush away, and found a 4' x 6' root burl attached to this one trunk. The other two trunks (and a lot more root burl) are still there, and I go by occasionally after big heavy snows or ice storms. Must be the nostalgia of the thing.... ;o} Where, exactly ? ... well, I'm not saying.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Box Elder HELP
Andy DiPietro
Re: Box Elder HELP
Andy DiPietro
>Wow! again, great job. That was a lucky day for you. What hollowing tools do you use to go 12" deep through a 5/8" hole??
Re: Box Elder HELP
Brad Vietje
Re: Box Elder HELP
Brad Vietje
>Hey Andy,
I was really pushing it on this one -- sort of a self-challange piece for me about 3 years ago. I used pair of 1/2" diameter shaft Ellsworth-style tools I got from Michael Hosaluk with 3/16" cutters -- one straight and one angled. Not an easy ride at all! Because this is pretty darned weak wood, I left a lot more mass on the outside of the base while hollowing the inside for strength, then finish turned the outer profile of the lower 3" or so between centers. I have bigger tools now, but really wanted to keep the opening small on this one. VERY few buyers will ever appreciate these small details, only other turners.
Safe spinning,
Brad Vietje
Newbury, VT
