THE WOODRAT IS BACK!
Motors
Motors
Motors
Leslie S
>Does anyone have a suggestion for a source for a motor to use with a Beal system. I turn on a Jet Mini and have 8 inch buffing wheels. makes for a tight fit when trying to polish. I have seen them in cataloges for a few hundred dollars, I figure there has to be a better price somewhere. Any ideas?
Re: Motors
Re: Motors
OB O'Brien
>Used washing machine motor.
Re: Motors
Re: Motors
Wally Dickerman in Arizona
>Look up Electric motors in the yellow pages. Most motor shops will have used motors for not much money. A 1/4 or 1/3 HP motor will do just fine for the Beall system. Make sure that it's turning in the right direction before you leave the shop.
Wally
Re: Motors
Re: Motors
Leslie S
>Next question. How does one make a motor for a Bealle out of a Wahing machine motor?
Re: Motors
Re: Motors
Russ Babbitt
>When I upgraded the motor on my bandsaw I used the old motor for the Beall system. Ebay would be a good source for new or used motors. Amazon, Harbor Freight and others already mentioned. Flea markets and garage sales.
Re: Motors
Re: Motors
Allen Neighbors
>Leslie, I located a motor that turned 1725 RPM. Then I attached an arbor (one that adapts the motor shaft to accept a grinding wheel) and re-threaded 1" of the arbor shaft to 1/2" threads to accept a 2" longnut. I screwed the long nut onto the arbor - tight - which left a 1/2" female thread. That accepts the buffing wheels I made that have a 1/2" bolt in the center.
My buffing wheels are quick to get on and off, using only about 1/2" of threads.
I don't know how the Beale buffs mount, probably different than my homemade ones, but this should give you an idea or two.
Hope this helps.
Re: Motors
Re: Motors
Bill Hale / Woodspinner
>Leslie
You can also check out Surplus Center on the web. They have cheap motors of every size and type.
www.surpluscenter.com/
Cut and paste this to your browser
Bill in Casa Grande, AZ.
Re: Motors
Re: Motors
>You should be looking for a 1725 RPM motor for the Beall system, not a 3450.
Wally
Re: Motors
Re: Motors
OB O'Brien
>Beall has an attachment for a 1/2 or 5/8 ths inch shaft. The shaft of the motor has a flat on one side. You screw 2 set screws down to hold the adapter on. The buffs can then readily be changed. Here's a link for the system that shows it all.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=123901&Category_Code=
Watch the links wrap around. Good luck OB
Re: Motors
Leo Van Der Loo
Re: Motors *LINK*
Leo Van Der Loo
>Hi Leslie
Leslie I used a used oil furnace fan motor, 1/3 hp and 1725 rpm, I made the parts to put the pieces together, but you can buy those readily.
I use a keyed drill chuck as I had one, but a hand tightening one would be even quicker.
Here's a picture and also a link to the parts if you like to buy those.
Have fun and take care
leo Van Der loo
http://www.leevalley.com/wood/page.aspx?c=2&p=41743&cat=1,43072,45939
Re: Motors
Re: Motors
Dinyar Chavda
>Is there any reason why you're not using the lathe? There are adaptors to hold the wheels either using a taper, or a threaded sleeve. The advantage of the lathe, of course, is that, assuming you have one with variable speed, you can adjust the speed to whatever you want it to be.
