A55 Smoothing Plane
Sharpening Turning tools
Dan Clermont in Burnaby
>Hello Everyone
Friend of mine recently sold me his Jet mini lathe and another friend gave me some Shopsmith turning tools
I have a Delta 8" grinder with a 60 grit wheel. Wheel is good for shaping but the edge off it leaves substantial tearout on maple burled wood.
Made a tool rest I am very happy with and my budget is small. What is the best bang for the buck to get a serviceable edge on turning tools? Can I get away with my 60 grit wheel and some sandpaper stuck to MDF sticks (ala scary sharp) or do I need to get another wheel like a 120 grit?
Cheers
Dan Clermont
Re: Sharpening Turning tools
>I'd get another wheel. Preferably at least 100 grit. You didn't say if your grinder was low speed, variable speed or "high" speed. Check the rpm rating of the wheel before you order/buy one.
>Dan I think 60 grit is fine but you probably have a gray wheel. I think a white wheel gives a better finish on the tool. However I used a gray wheel for at least 10 years so it's not a major problem. The problem your having is probably more related to your sharpening skills and the cutting angles you are using on the wood.
If you grind the tool carefully and then use the sandpaper on a stick you should get a very good serviceable edge.
The trick to getting clean cuts is always cutting down hill with the grain. Cutting with the edge slicing the wood and the bevel rubbing. To see if you are rubbing the bevel of the edge put the tool into the wood with the handle very low so the edge won't cut. Then lift the tool until it starts to cut. That's the angle you want the tool. If the edge is 90 degrees to the rotation of the wood you will still get a fairly rough cut. Try rotating it so that it's about 45 degrees to the rotation with the bevel still rubbing of course. The try not to force the tool through the cut. Relax and let the tool do the cutting. Then you should be getting pretty good cuts. some wood still tears out a little, especially old wood that's been sitting for a while.
Jim Shaver Oakville, Ont.
>Hi Dan,
I went with the white Norton 80 grit wheel from Lee Valley. I am a big fan of the OneWay Wolverine sharpening system, but LV sells a tool rest that is less expensive that always seems to do well in magazine reviews.
You have just begun, I have spent more on my lathe tools and chucks etc than any of the options I have for my other shop power tools, not including hand planes!
Hope that helps,
Jim
I have a Jet Mini and a General 160, I love turning on the mini...
Greg Haugen
>I prefer a 60 grit wheel. I do more hollowing and bowls and for me a 60 grit wheel is prefect. John had a good point though a white or I prefer pink ($30 from Woodcraft), they resist grooving a little better which means less dressing and longer life, would be better than a gray wheel. But it will work. The main thing is dressing. Making sure the wheel is clean, flat, and running true.
Good luck. There are very few "rights and wrongs" in woodturning. The main one skews and roughing gouges (spindle) should never be used on bowls. If you asked 10 turners a preferred grit for sharpening you'll get 10 different answers. Find someone locally and try their wheels, etc. Experiment. Find something that works for you and use it. Have fun.
Greg
Leslie S
>Does anyone have a suggestion for a source for a motor to use with a Beal system. I turn on a Jet Mini and have 8 inch buffing wheels. makes for a tight fit when trying to polish. I have seen them in cataloges for a few hundred dollars, I figure there has to be a better price somewhere. Any ideas?
>Scrounge for motors. I use my big lathe but my 2 best friends have 3 motors with the Beal wheels permanantly attached. I know one of them is a washing machine motor. I just hit the flea mkts and pick up motors whenever I see one at a good price. You do have to jury rig the mounting sometimes. There are lots of adaptors out there to fit the various motor shafts.
Leslie S
>Sorry about hijacking the post I meant to start a new thread!!!
>Thanks for the input everyone.
The grinder is an 8" Delta Variable Speed grinder with a 60 grit white wheel.
I think it may have more to do with technique as I have not been riding the bevel down till it starts cutting. WHat I have been doing is "poking" the wood and probably creating a cutting angle which is too severe.
Finished up mmy first pen today and passed it on to my Mother. SHe is pretty happy with it. I did quite a bit of sanding. Dad indicated he might be into trying to turn a pen so I may set him up tomorrow. FWIW, my parents are in town for a visit and were amazed at the pen I made for them last year on a friends lathe so I thought they may like to try to make one themselves
Cheers
Dan C
Re: Sharpening Turning tools *LINK*
Darrell Feltmate
>Try heading over to my page and looking at the instructions for making a grinding jig. It is a cheap solution for a lot of problems. Also look at the grinding profiles here. I find them a lot of help.
Around the Woods
