Grinder quick-stop modification
Rick R
>Most of us have probably experienced the annoyance of having to wait and wait for the grinder to stop so we can re-adjust the tool rest or grinding jig. On my 8" 1800 RPM grinder, the wait is almost 1 full minute. I made this quick modification so I can stop my grinder in 4 seconds. Now I can make a grinding pass, check the tool, stop the grinder, re-adjust the grinding jig if needed and make another pass, without having to wait, wait, wait, so I can get back to turning quickly. For normal coast to stop operation, I just flip the toggle switch from ON to OFF. To stop it quickly, I press the toggle from OFF to BRAKE until the wheels stop, then release. A little spring pushes the toggle back to OFF when released.
The modified toggle switch replaces the stock switch. It is a center-off double-pole double-throw, with a slight modification to make one side momentary contact. For the DC source, I used an old 12V car battery charger. The grinder draws about 8 amps in brake mode. If you want to try this, but have doubts whether it will work, hook up a 12V DC source of a few amps to the prongs of the AC power plug of your grinder, turn on the switch, and try to turn the wheel. You will find that the magnetic force wants to keep the wheels from turning. Feel free if you have questions.
Rick
Re: Grinder quick-stop modification
Dennis in Southern Oregon
>That's clever Rick. Just be sure that the nuts on the wheel shaft are tight. They tend to spin off if the deceleration is too high. Dennis
Jerry Hall
>Great idea. I have solved the problem by taking my diamond "T" wheel dressing tool and holding it to the stone to stop it after hitting the off switch when I need to stop quickly to adjust the jig or platform. The stone nearly always can benefit from this anyway and this way it never gets too bad.
I use
Terry Quiram, Roanoke Illinois
>the same crepe rubber block I use to clean my belt sander to stop my wheels when a hurry.
Dick Hines
Dick Hines
>Good job Rick but don,t think I will evey hook one up to my grinder. I just am not in that big of a rush.
>Very interesting Rick. Personally I grind a second bevel on my tools so the heel of the bevel is rounded. On my spindle gouges I grind away quite a bit of the thickness at the tip so they are thinner and will reach into tighter places. Why am I telling you this. Because I will grind the edge, then turn the grinder off and grind the second bevel. It stops the wheel quickly and I haven't wasted any time.
Carole Valentine
>Ditto. I also use the grinder in "coasting" mode to sharpen some of my little tiny tools.
my solution
OB O'Brien
>I turn the wheel by hand and look at the edge to make sure its lined up correctly. By doing this by hand it takes off just a little bit of metal. You can tell the difference by the shiney part. Then turn er on and grind it. I don't need to stop it. But your mod is neat, I think it would be great for a table saw safety measure. Thanks for posting. OB
