John Jordan Hollowers Review
Greg Haugen
>Recently I purchased the large set of hollowers, armbrace handle, sharpening jig, and the shear scraper from John and Vicki Jordan. I have used the Bosch, Stewart, and Kelton hollowers in the past. I tried John's and found my tools of choice. I like the fact there are two different sizes of hook tools. At first I only ordered one, #1, but soon I did enough to find out #2 is very helpful to have so I ordered it as well. Other hook tools on the market are around 14", John's are 16" and 20". The straight tool is also 20" which makes even some of the "furtherest" reaches comfortable and possible. The contour or "profile" of the hook tools make getting around corners and in and out a small hole a easier task. As John says on his website, "these are the best hook tools." I have to agree. I also like the set screws that hold in the bits. Along with a sharpening jig, being able to easier remove a bit and sharpening it with the assitance of the jig is alot easier than trying to juggle a hook tool with a glued in bit on a platform.
The armbrace handle I wasn't sure about it until I used it. It is very comfortable. The ergonomic shape and the rubber covering provide outstanding comfort and control.
The shear scraper, what can I say other than WOW. I turn a fair amount of bowls and I'm used to the shear scraping of the outside of a bowl with a gouge. The shear scraper does a better job and it's easier to use. If its the outside of a bowl or the shape of a hollowform be able to remove any and all tool marks and tearout to a nice smooth finish pays for itself in sanding time. If you sell pieces this tool will pay for itself in less sanding time.
This is my review of my new tools. I'm in no way connected with the Jordan's. I'm just a very happy customer.
Re: John Jordan Hollowers Review
>Greg I'm doing a hollow form today and just finished using John's shear scraper. I love that tool. I do a little finish shaping to get rid of any lumps and tool marks. Then I put a fresh burr on it and do a final really light pass. Voila, start sanding with 180. This is very old Elm or I might be able to start with 220.
I've been thinking about buying John's armbrace. I have a homemade stewart looking handle and I've never been really comfortable with it. I do have homemade John Jordan style tools and I love them.
ditto on both reviews
e
>I REALLY like John's shear scraper!!! It's one of my most used tools. Takes only a few moments to refresh the burr and solves many grain problems.
I've been using the large and small hollower sets for years now -- they are my favorite, most-used hollowers.
an excellent investment.
Re: I bought JJ's because ....
Jamie Donaldson
>... they are what I would have made if I had the capability, and they fit both my Stewart armbrace handle and Jamieson D handle boring set-up. The finish also just happens to match my JJ Stubby- that Jordan guy knows what he's doing!! ;-)))
eliot d
>I have both of the Jordon swan neck tools and also like them very much. I have seen --but don't have -- his scraper; it sounds like I better get it from what you say. I have not seen the jig for sharpening the bits. Can you explain, roughly, what it looks like and how it works?
Greg Haugen
>Here is a link to the "tools" page of his site.
http://www.johnjordanwoodturning.com/tools.htm
The jig in the picture is used freehand (without a fixture). It doesn't go with my wolverine, the "pocket" in the V arm is to far back. My grinder is screwed to a "doubled up" piece of plywood and the wolverince is also on it. That way the whole thing is mobile and still consistent. I have handles on the far sides of the plywood for easy carrying. What I did is drill a variety of holes in a piece of dry wood. So I can remove the v arm and place the wood at in front of the grinding wheel. Place the stem of the jig in one of the holes at the corresponding angle and sharpen the bit. That way its anchored in a hole and doesn't slide around. This gives me a very easy and consistent sharpening. The jig can be used in this manner or freehand. It gives you more options with sharpening bits and keeping your fingernails intact. And your not try to sharpen with a hook tool on a platform, that can be a juggle.
Hope that helps. It's not as a big deal as I'm sure I made it sound.
Greg
Brad Vietje
Brad Vietje
>The Jordans are extreemly nice people and John's tools are top-shelf all the way. I have the hollowing tools, and love them -- will have to request the shear scraper from Santa !
Safe spinning,
Brad Vietje
Newbury, VT
Another happy JJ user...
Jennifer@Indy.USA
>I love my JJ hollowing tool. I use it in a Don Pencil arm brace. I still have not yet figured out why it works so much better than the others, but it must be the angle of the cutter, and the shape of the curve in the end. It does give a sweeter cut with little to no chatter. I do need to get the sharpening jig. I keep thinking I'll try to make one, but never get around to doing it.
Jen
JJ Jig
tek-Brunswick, Ohio
>Here is how John Jordan told me to set up the jig. Keep your Wolverine set up for your most used grind, usually the bowl gouge grind. Hold the JJ jig with the cutter up to the grinding wheel, with the grinder off and the bottom point of the Jig leg on the Wolverine slide arm. Match up the angle on the cutter with the face of the grinding wheel. When you have the grind angle right, mark the spot where the jig point sits on the arm. Now put a dimple in the arm at that point. I used a spring-loaded center punch. Now when you want to sharpen the JJ cutter just put the point in the dimple and sharpen. And the V pocket on the wolverine is still set up for your bowl gouge grind. It works like a charm. I too am a fan of the John Jordan Hollowers and found him very informative at the "Dessert Woodturning Round Up", where I bought my tools from him.
Re: Another happy JJ user...
>I think it's the size of the cutter. The smaller size lets you be aggressive if you want but if your gentle it will be kind to you. I like the fact that I can go down to my local machine shop and buy another cutter if necessary. don't need to special order anything. I bought a dozen of them last year for 75 cents each from Enco. I make ornament hollowing tools, or other hollowing tools out of them.
Thanks!
John Jordan
>Greg, and everyone,
Thanks for the nice comments, it's sincerely appreciated, and I'm glad the tools do what you expect.
I don't log on here as often as I like, and I try to never do a sales pitch, but: If any members of Wood Central are interested in tools, I will give a 10% discount until Christmas. Just email or call and mention Wood Central to Vicki.
Good turning to all. :-)
John yea, I know it's a crappy web site.
Re: JJ Jig
Greg Haugen
>Hey thanks for the info. Now I have two ways to use it. I did make a dimple on my V arm. Its a little easier than the wood. But if someone doesn't have a wolverine, they should get it, :-) and in the mean time they could use a block of wood. Excellent information. Thanks alot. I love sites like this for this reason.
Happy Turning.
Greg
