pulley belts
pulley belts
pulley belts
eliot d
>I know that for many pulley/belt systems people prefer those belts that have all those links. Are these recommended for a lathe? Would they be smoother, quieter, less likely to slip?
Re: pulley belts
Re: pulley belts
>I put them on my old lathe because I had them laying around and it was easier than buying another standard belt. I could not tell a bit of difference. I replaced the belt on my table saw with one thinking it would reduce the vibration. Not a change. They hold up well and of course changing the size is very easy, but I haven't seen an advantage in vibration reduction. There may be some noise reduction if you have a squeeky belt but if not there won't be any change.
Others may have different results.
Re: pulley belts
Re: pulley belts
Bill Howatt
>I put one on my contractor TS and it did reduce the vibration a bit. This is probably because on a saw like that the motor hangs against the belt and can put a "bump" in it; the link belt is much more resistant to taking a set than a regular belt. If the set isn't too bad it will disappear or be diminished in a short time.
I have found that I can get a slightly better grip with a link belt on a very small pulley on my bandsaw.
An advantage for using a link belt on some lathes is that you don't have to remove the spindle to put a new belt on the machine.
billh
Re: pulley belts
Brad Vietje
Re: pulley belts -- Gimmic ?
Brad Vietje
>Well I've been known to go out on a limb before (usually in search of a burl!), so I'll do it again...
I have a suspicion that "link belts" are more gimmic and marketing than a real vibration dampener. As a man of science, I'll admit that I could be swayed by real date from an objective source, but as an intelligent and literate person with a pulse, I have a healthy dose of suspicion about in-house data and corporate claims of effectiveness. My sense is that these things spread out vibrations into many, many smaller ones, which may help in some situations.
I put linkbelts on two machines in my dad's shop a few years ago, and besides a lot more crunchy-squeaky sounds and a sort of white noise background sound from all the increased wind resistance, there wasn't much change at all, though it did take much more change to buy these than the alternative. They DID seem to help when running equipment before the cold shop was fully warmed up. By cold I mean AM temps of near zero (F) to near-freezing (usually 20 degrees colder outside), and after only 30 minutes of heat or so. Cold V-belts can get pretty stiff, and they can cause a lot of vibes. We also resurrected an old buffing machine with a 50-year-old belt that seemed to have petrified with two permanent bends around the pulleys, and not having a spare on hand, we sized up the expensive linkbelt, which was, indeed, a major improvement.
For replacement of relatively new belts, or those in decent condition used under normal shop temperatures, the biggest benefit may just be the increased air movement -- it did seem a little cooler turning on hot days with the link belt installed. :0)
Safe spinning (and truth in advertizing!),
Brad Vietje
Newbury, VT
Re: pulley belts
Re: pulley belts
Steve in NC
>Link belts do not work with a reeves drive.
I put one on my TS and saw little result. Then I chages to machined pulleys and saw a dramatic reduction in vibration.
Steve
Re: pulley belts
A number of years ago
Don Henthorn
>there was a post in one of the forums (can't remember which one) mentioned a study which found that common cogged belts which can be bought at most auto parts stores did as much for reducing vibration as the expensive link belts.
Re: pulley belts
Beg to differ Steve
Dave Peebles Lyons, Ohio!
>I have heard this statement before Steve. But it worked great on my old Boice-Crane lathe. I had a link belt on it for several years with no problems at all. I believe that most problems occur with some of the less heavy duty reeves drives on the newer Jet and Delta lathes. They cannot be be compared with my old beast. It was build like a tank. :)
I also found the link belts to be a great improvement to my old Craftsman table saw. That, in addition to the steel sheeves in the kit made a world of difference on my saw. It felt like I gained a full 1 horsepower when ripping 8/4 maple.
ymmv
Best wishes,
Dave
