Re: Lighting at Lathe
Bill Hale / Woodspinner
>I use a 500 watt halogen mounted on the ceiling and 2 ceiling mounted reflectors with 100 watt inc. in each. I also have a floor stand that I can move around with a 500 watt halogen in it. I use this one primarily to see inside bowls when turning the inside.
NOTE OF CAUTION--- When using the halogens they get very hot so remove the wire guard from the front. I had the experience where some shavings got hung on the guard and started to burn. They were droping on the floor with the other shavings when I saw them. I got it out prior to any real flames !
One thing I do to keep electric cost down is all of my lighting is on X-10 switches and when I don't need them I just hit a button and they are off.
Good turning and be safe
Bill in Casa Grande, AZ.
