Have a question? Ask Woody!
Small Cone for Oneway
Stuart Johnson
>The Oneway live center came with a large bullnose cone and full point cone. Where can I get a small cone that is used for center square pieces? I've seen photos of them being used but can't locate one.
Re: Small Cone for Oneway
Bart Rhoads
>If I understand you correctly, when I purchased mine a few years ago, it came with the small pointed cone. It was 2" in dia at the base. You might check on this, you might have gotten shorted when you purchased it.
Jim Pugh, Elyria, OH
>Stuart, if you take the small cone off there is a cup center and a removeable point. Is that the size you are talking about? Otherwise, take a piece of wood, drill and tap it for 3/4-16 thread and screw it onto the tail center thread. Put the tail center in the drive end of the lathe, put an allen wrench thru the lock hole and tape it securely in place. Now you can turn what ever size/shape center you want.
You can use this method to make cup centers for turning spheres also.
Brian McKearney
Brian McKearney
>Mine came with the cones shown in the picture. Are you referring to one of these two cones or something different?
Brian
Stuart Johnson
>I don't think I explained myself very well. What I'm talking about is I guess a cup. It is like the large bull cone only smaller. It is placed on the live center with the large opening against the square spindle and keeps it centered.
Bob Elliott
>Jim,
That's 3/4" x 10 tpi
Packard
HeatherA in Alaska
>Packard woodworks (packardwoodworks.com I think) sells the replacement cones for the oneway center.
Heather
Bill Hale / Woodspinner
>Stuart
I too am a little confused as to what you want.
The large cone can be mounted in either direction < > on the tail stock. I have not seen a small small cone without a point for threads. If that is what you need just make one any size you need.
Turn a cone as needed and part it off. Use a drill press to drill out and thread as you need to fit your live center. Mount it and re true using a thin mandrel to drive it.
It you use a good hard wood there is no problem threading with a metal working tap.
Hope this is what you need.
Good turning and be safe
Bill in Casa Grande, AZ.
Stuart Johnson
>Bill, The > with the point toward the tail stock is what I mean. I saw it being used on small pen sized spindles. I thought it was attached to a Oneway live center but I guess it might have been a stand alone. I'll make one up and see how it works.
Thanks everyone for the help and for not calling me an idiot :)
Re: Small Cone for Oneway *LINK*
HeatherA in Alaska
>I was wondering if this is similar to the picture you are remembering. It is at the bottom of the page.
Heather
http://www.newwoodworker.com/reviews/onewaylivecntrrvu.html
Thank you Heather
Stuart Johnson
>I think that might be the photo I saw or at least it is the same idea. I'm looking for something much smaller and have decided to make my own.
E Tabachek
>Stuart
Craft Supplies, USA, carries the Axminister live center that comes with a small cone insert. I will try to include the link. Over the years other manufacturers have made these cone centers, including Record and Multistar (both from England). These cones were used (in both HS and TS) to hold lace making bobbins.
Edward
http://www.woodturnerscatalog.com/cgi-bin/shopper?search=action&keywords=axminster-interchangeable
