drum sander
drum sander
drum sander
Claudia Hayward
>I'm thinking about buying a small drum/thickness sander and hoping you experts out there can give me some advice. The best price I can find is at Grizzly tools with their small 12" GO459. This is in my price range and I wondered if anyone has any experience with it. Quality? Enough power? All opinions and suggestions welcome!
Thanks...
Re: drum sander
Re: drum sander
Tony Reynolds somewhere near Newark, Ohio
>You may get more responses over on the general message board, but it really depends on what you plan on doing with it. If you plan on using it in a production way the the answer is you won't be very happy with it. I have a 18/36" unit and it's fine for light duty use on small width stock but lacks the power and speed to do anything 18" wide unless you want to make dozens of very light passes. I mainly use mine to sand narrow stock and thick sawn veneer etc. It being called a thickness sander is a bit of an overstatement.
Tony
Re: drum sander
Re: drum sander
Carol from AZ
>I just looked at the specs. I used to have a 22/44 Perform-Max. I am not sure it weighed 199 pounds! Had the same HP motors. Light passes are what it did best. Sold it when I moved because of its footprint.
Given what I know and have to expect from this kind of a machine, this one intrigues me. When I am back in the market for one, I will certainly take a closer look at this one. I do own several Grizzly machines and am suitably impressed with each of them, so that has something to do with it as well.
Just don't expect it to be a benchtop planer. It ain't. None of them are. When I taught at a community college, we had a 12 HP wide belt sander. That took multiple passes as well. Sanders are sanders and planers are planers.
Re: drum sander
Re: drum sander
Malcolm Tibbetts
>Claudia, my experiences with drum sanders are limited, but regardless of brand or size, I recommend one that has support posts on both sides on the drum.
Re: drum sander
Re: drum sander
>The new steel city tools sander has support posts on both sides.
Re: drum sander
Re: drum sander
malcolm Connor
>I have the Grizzly 16" drum sander that I would like to sale. It's almost brand new and in perfect condition. I bought it for sanding segmented rings but, it need a board at least 9" long and I make lots of rings that are shorter than that. I have several Grizzly tools like the 19" band saw and 3hp table saw - very happy with them.
Sander used less that 30 minutes its brand new. Will take 650 dollars but it's pick up only - I'm located in Georgia
thnaks malcolm
Re: drum sander
Re: drum sander
>Gang the rings together. I used to run small pieces through the planer by hot glueing them to a longer board and running 8 or 10 at a time. You probably won't have to glue them on the sander. I think you could just butt them up against each other. someone let me know if they've tried this.
Re: drum sander
Re: drum sander
Claudia Hayward
>Thanks everyone for the input. I'm not worried about it doing a planing job as I already have a thickness planer but that tears up highly figured wood something fierce. Malcolm, thanks for the comment about the support posts, I'll keep that in mind. And I was pleased to hear the positive stuff about Grizzly, never bought anything from them as I am north of the border, but I'm close enough to their Bellingham warehouse that I could consider them.
I'll keep thinking on this one....
Re: drum sander
Re: drum sander
Stuart Johnson
>I've noticed this length limit on other sander specs. Couldn't you build a sled to carry the rings or short pieces?
Re: drum sander
Re: drum sander
malcolm Connor
>Yea thanks John - I tried the hot glue route and it works, but, it's lots of trouble compared to my friends performax sander which will take a length down to 2 inches. I just might have to try the sled with a stop on the end and just let the rings touch. thanks john
Re: drum sander
Re: drum sander
>I thought about using some spacers and wedges on the ends to hold all the rings solid. Kind of like printers used to do to wedge the type in the tray. That might work if the carrier tray had raised ends and sides. Just fill up as much area as you can with rings and then add some spacer blocks and a pair of wedges and everything should be secure.
Of course that's one of those things that sounds good on paper but may or may not work.
Re: drum sander
Leo Van Der Loo
Re: drum sander *LINK*
Leo Van Der Loo
>Hi Claudia
Have a look at these surface sanders, you might like those a lot.
Those are nice people to deal with and it is also Canadian made quality, and no border hassles, brokerage charges etc.
Have fun and take care
Leo Van Der Loo
http://www.stockroomsupply.com/V_Drum_Sander.php
